Looking at a Tomei Extreme Ti cat back exhaust system but want to confirm what the ID of the rear muffler is. Has anybody actually seen one or own one...measured one?
I understand the tube diameter is 89.1mm OD, just want to make sure the muffler does not drop in diameter to 3" etc
  • Replies 100
Yeh, but if I am spending that much money on an exhaust I dont want it to cost me a single bloody kw. I only make 250 odd :( I have some prices for some thing guage stainless mufflers and pieces and if I cant get a solid answer on this exhaust will be going twin 2.5" with a 4" dump with wastegate plumb back in. I currently lose around 6-7% of my power when I plumb the gate back in so need to improve over the HKS Hyper i currently run
the solution to your power woes??
open up that screamer :thumbsup:
fab up a removable piece so you can remove it and reinstall at anytime which shouldn't take long to do.
I don't know how anyone can drive on the road with a screamer, I only lasted a few days of not being able to boost at all for fear of instant defect, car crushing, death by firing squad on the side of the road. But then I do live in Victoria...
Tracks have DB limits too, on some cars they dump the exhaust out different sides depending which side of the track the pits (read microphone) sits. An open screamer would have no chance.
must be a Victorian thing.
Wakefield and Eastern Creek in Sydney, don't have noise restrictions.
wakefield does have noise restrictions, there is a mic in the middle of the grass patch near the main straight.
but they allow open screamers, your car must be insanely loud for them to pick it up and kick you off the track.
ok i just checked the wakefield regs, it says max limit is 95dB at 30m,
they must be very lienant with this as ive seen alot of GTRS/V8/cars with open screamers go there without an issue.
Noise can vary in DB with something a simple as a wall.
Most tracks have restrictions. And then also some have "X" amount of "unrestricted" days.
Just a matter of if you get pinned or not, and that depends then on the position of the pickup
Bris, Buy a 3.5" Borla/Magnaflow etc Stainless muffler from Summit/Jegs take to a decent exhaust shop and have a system made made, wont be titanium, but wont be any doubts about the muffler quality either
+1.
In fact just got a new full 4" system using Magnaflow's Troy. 6" body Cat as well. Worth thinking about - at least you know exactly what you're getting.
I'm a jdm fan to my detriment with some of the parts I buy... Incliding exhaust's for the most part.
But for the money, I'd carefully consider custom Ti pipe work (Appropriate grade Ti mandrel bends can be purchased in the US) with slip jointed 'Burns Stainless' center resonator/s and a brand name rear can.
The thin wall stainless pipe work 'Burns Stainless' stock are only a poofteenth heavier than the same size Ti
Cheers
Justin
But for the money, I'd carefully consider custom Ti pipe work (Appropriate grade Ti mandrel bends can be purchased in the US) with slip jointed 'XXXX Stainless' center resonator/s and a brand name rear can.
The thin wall stainless pipe work 'XXXX Stainless' stock are only a poofteenth heavier than the same size Ti
Cheers
Justin
Don't go posting this stuff up on SAU. The real good gear you need to keep quiet and to yourself :) I did an exhaust with a friend years ago when I lived in Sydney and had after hours work to my old employers factory, tools etc. Their gear is top notch and I was planning on using two of their real mufflers in a twin system.
What I need to find is a centre muffler that has a 4" inlet and twin 2.5" outlet
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
