oh really? shit.. I've been driving on the streets with them to the track LOL...
been pulled over once and a copper said they look bald.. so I showed him the tread indicator and he was happy they were above the indicators and off I went
DOT? We're not in America. These are DOT too:
NT01 have no load index rating on the sidewalls. They're not road legal in Australia. They're not CAMS approved either. They're not good for much at all really.
Edited by hrd-hr30
Are the nankangs road legal?
I reckon 265 vs 265 Nitto v nankang that they would be very similar speed, but also willing to bet the Nitto would be more consistent over the lifespan of the tyre and the nankang will fall off.
Yet you hold such a grudge.
Anyway I'm over it. Back to real data and no more speculations.
lol Silly me! I thought I had real data having used both tyres on the same car. I defer to your "I reckon" and "I bet" guesswork based on never even having seen one of these tyres...
Edited by hrd-hr30
  • Like 1
no, but your post did - you asked me a question (yes the Nankangs are road legal btw), then told me I hold "such a grudge".
NT01 are consistent, that's true. But you can't lose what you never had :P
AR01 could drop off at least a second over their life and still be as good as brand new NT01s. The soft compound Hankook Z221s when they had totally given up the ghost and were sliding around all over the place were still faster than the NT01s, but it was time to chuck them out as absolute garbage.
What the Nankangs do over heat cycles remains to be seen. I've had tyres that heat cycle really well and ones that deteriorate very quickly after a handful of track days, but I certainly can't tell which would do what from just driving on them once, let alone just from their brand name.
FWIW, Nankang has technology licencing and technical support agreements with Yokohama... That's from Yokohama's website, not Nankang's - they don't mention it at all. Who knows how much of their technology is involved with the AR1, but it was one of the factors that encouraged me to take the gamble on these $209 semis! lol I wouldn't be so quick to write them off before trying them.
I'm keen, but they need a new name LOL
call them Yokakangs.. I will buy
Nankangs, no...
I nearly killed myself 10+ years ago on Nankangs NS-2.. now that I am older, wiser and have some form of cash flow I refuse to buy Nankangs.
Nt01 is only a intro semi which back before the rsrr was released they could be had for the same price.
This argument is silly.
I agree, because Nitto has beautiful women promoting the brand so it must be good.
  • Like 1
lol this thread heated up ;) I've used NT01's which are a real semi slick and not bad but not up there with the best for racing in 2016. One thing with Harry's reports is that they are roughly comparative with the other tyres he has used so to dismiss them outright is just plain dumb. Then again he won't say what cold pressures are used so...........
Agree that testing with the same car and driver is the best evidence. Not sure why you think his cold pressure is a big deal, just play with it and see what works. Will be different on different cars anyway.
1. They're the slowest semi money can buy.
2. They're not road legal so you can't even legally drive to the track on them which is a PITA.
3. They're not CAMS approved for production car classes.
You're better of doing very similar times on street tyres, or buying literally any other semi (other than R888 :P)
What's wrong with the R888 (besides being the same compound as NT01)?
The replacement tyre R888R is street legal, it'll be interesting to see if the upcoming NT01 replacement will be too, and whether they'll again share the same compound.
Also the NT01 vs. RS-RR comparison seems a little odd, they're a different category tyre aren't they (100 treadwear semi vs. 140 treadwear street semi)?
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
