Also comparing 250kw (thats well over 400hp btw) on a road with potholes and telephone poles and all sorts of other scary shit that can and will kill you or somebody close to you very very quickly and unexpectedly..
To having 250kw on a controlled skidpan, dragstrip or racetrack is again comparing apples with oranges..
Actually... It's 335HP not well over 400HP...
Have kids just started failing simple maths lately?
  • Replies 106
lols...tell the truth you googled that..
crank hp is what I was suggesting,(probably should have stated) I guess you failed the mind reading class :P
20yrs ago when boosted turbos and dynos werent so common, if you had a 400+hp street car you were the man...
It is still enough for a very quik car but people seem to lose sight of that...
Ummmmm just me but 250 killer wasps is not well over 400hp
Oh and this thread is pointless
As nismoid said too many factors like diff ratios gear changes etc go to an import yard and test drive something quick
Its worse than that, they're failing youtube
Okay, this whole thread I've been facepalming something shocking at the stupidity... I get to this and nearly wet myself laughing...
BRB, going toilet...
That reminds me - here's a .82a/r internal gated GT3076R setup with similar power:
Its over 250kw, not quite 300kw - so doesn't answer either of the specifics but still gives an idea of what a very basic internal gated GT3076R setup can go like with a safe tune.
That turbo is capable of much more on more boost/better manifold/external/cams etc, but still makes for a good all around setup.
This seems WAY faster than youtube vids I've seen of sub 240rwkw skylines, but as Nismoid says, too many factors to judge the reality, nevertherless still a good means to get a good idea for people wanting to set their power goal.
That reminds me - here's a GT3076R setup with similar power:
Thanks mate I did see that on youtube before and was goin to post it, you beat me to it..Thats fast man - must be around 280-300rwkw seeing its a 3076R.
Edited by rondofj
Yep it was in that range on the dyno I tuned it on and it seems thats the generally accepted range for that type of setup on that type of boost.
I didn't mention numbers as people on here get all weird about dyno types - so stuck with the basic facts, this is the kind of performance you should get with a stock RB25, stock manifolds, decent exhaust intercooler and ECU and about 17psi running on 98RON. Tune and all else being equal the real world results shouldn't vary too much, regardless what kind of numbers on what kind of dyno.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
