  • Replies 7.5k
Posted Images
schmenz: Spotted Miss R34 today at the lights on Payneham road, where the BP on your right was, i was the girl with the two guys walking past... actually i was telling them that your car is hot, lol.
:P HI! you should have waved cause i would have waved back!!!!!!!!!!!!!!!!! lol
Spotted MISS33 at the Golden Grove Village today, parked next to her, love the color :D
Saw a few nice cars today;
Grey R33 GTR on Main North Road 4:30 at Hampstead Gardens, gave the dude driving a nod...
Black R33 (GTR I think) on Wellington Square in North Adelaide, waved to driver.
My boss borrowed a silver 200sx from somewhere. Very nice ride. Also saw Red and Blue 200sx's today as well as a White R32 GTR without a spoiler (and a very dirty rear end) parked in the city (forget the street)...
-D
spotted i think he said his name was Rob 'RB25DET' @ aussie dicount mufflers today when i hopped on the dyno did a speed calibration and power run
made 158AWKW @ 8psi couldn't run higher because coils were giving me greif
also spotted Pauly's dream car :D
yea hehe... its Ryan! yea was definetly a coil pack problem or spark gap. check your power steering fluid too man, i noticed the fluid bubbling around a bit...might be the pump cavitating, getting air in the system. i would have chatted a bit more but had to put a head back on.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
