  • Replies 7.5k
Posted Images
spotted a aqua greeny torquise kind of colour R32 crossing salisbury highway exchanged fellow skyline head nods of mutual respect :banana:
had diff front bumper(dont know what sort) with license plate to the side
very nice colour indeed
Edited by gzilla
^^ that would be import_s13 :rofl: kye and lauren
cheers heaps for that wheel matty it is slightly broken the horn button but it still works for now and is a lot better condition than mine
nah wasnt us lol
unfortunatly we know dan aka gzilla any ways so he would have known if it was us! :P
probably 'stepup'<--- they were the old plates is more of a green than kyes car
lauren
Edited by Import S13
Saw a nice 32 GTR, RBO-026 on Portrush rd look like he was heading to the Parade, but coulda been anywhere. Was in the old boys Merc.
Nice plates i may add and cheaper then most others round im thinking.
Edited by R32Abuser
spotted a black 34 and white 33 ripping through traffic down the bay all the way north today i tried to keep up but bloody hell mate damm they where crazy wrong side of the road overtaking between cars it was like playing the ps3
yeah that would be Alex matty, plates are RDRIPER - im guessing it means road ripper? Dunno, hes only just got them. Saw him again a few mins ago too on marion road.
Saw few others down the bay, stocky looking grey 32, white 33 with blue decals..
oh and sled was keeping an eye out for u and your bike, even checked the bikie parking area a couple of times lol
Hey Flick.....I was down there with the other bikes up until about 2.00pm........what times were you there?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
