  • Replies 7.5k
Posted Images
spotted: blue vk? wit white rims, the one from the drift comps going up brighton rd yesterday arvo. i heard they spend big $$$ (8 or 900) on a handbreak for the comps. (put on a good show....for a commonwhore )
did ne1 here go on the boosted cruize on sat night? there was a very nice dark purple r32 gts-t that i havent seen b4....loved that colour, sounded nice. would b interested 2 know what mods it had?
blue? yea maybe....kinda looked like the gtr purple to me (love that colour), but i didnt see it under light, just a quick glimps while trying to keep my poor sick(missing) car straight! (wet weather makes for some interesting driving!) souded like it had a bit of power tho....
HA HA A:bahaha:........I Reiceived a letter from VICROADS saying that people find my number plates offensive and that they promote poor driving. They have asked me nicely if i would concider changing my plates for free. Hey dean do you have a scanner so i can put this letter on the forum???! Any ideas for my new plates anyone? Oh and while iam on the subject my plates where ment to be COP Y ME not COPYME.
Why do you have VIC plates? But yeah, that's pretty funny. Buy a scanner.
Oh, and COPY ME is better than COP Y ME, IMO.
Moo_r32, did that purple looking 32 have a gtr kit on it, if its the one im thinking of it used to belong to a mate of mine, supposed to be a 400hp car (so ive been told) I know its got gtr intercooler, exhaust, big turbo (dont know what but its heaps laggy) custom exhaust maniflod and external wastegate, had extra injectors and ran 18psi or something, i think it used to have bbs rims on it. did it have bb licence plates?
I spoke to the owner (or formaer owner a while back), it had a Apex'i turbo, smallish trust intercooler (still in stock location) extra injector etc. I had a chat to him when it was for sale, as I thought it was a GTR. He told me it was making 185rwkw at 18 psi boost
Sounds like its had a few changes since if its the same car
Nice looking car
Dude don't attack me on the net, you don't know me!
AND how i drive my car is up to me, is it not?
Well considering there was no other car on the street except yours and mine. It was late and u decided to rev it up and launch it right next to me, im pretty sure that my guess of you showing off was true.
But dont worry, next time i see you and I dont have a passenger, ill chase you down and do it personally.
Morale of this story, if you wanna show off, go look for some other freak to do it to.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
