I no, i mite one day come to like them if I can sort what ever is wrong with the dam things.
Anyone got any sudjustions ?
Any "up, down, up's" in size in the exhaust?
Cam timing?
Tired engine?
Should be bout same as mine as almost same set up , i think should change cam timing to what mine is :)
The exhuast was farked when it made 330rwkw, 2.3inch front pipes into a 3inch catback than went down to 2.5inch in the cannon.
It's now got 3inch tuned length front pipes into a 3.5inch merge. Decat, and I'm just waiting on the 3.5inch tomei ti catback to turn up.
See how it all works out when the new system on bolted up. Than jez can do a full tune on it, cam gears, and all.
It's got type b pon cams.
Azza's made awesome power on the same setup I the same dyno.
His got a forged motor, but my motor is 160 across all 6 so it shouldn't b an issue.
C what happens
Not exactly the turbo's fault with the little 5's trying to blow out of that man.
So what's considered responsive with -5's? 1 bar at 3600 rpm?
from memory my rb2630 with -10s made 1bar @ 3krpm, I'd need to dig it up as I posted my results in each gear on gtr UK forum
Yea I no, the prob I had was I made up at 4inch system took it back to the dyno and only made 7kw more.
Im just saying -5 on something like your motor is crazy. It deserves a decent turbo. Gunna b awesome!!
Next time your under the bonnet man, could u have a look at what yours are set at? Maybe take a pic?
Let me know when your back and i will meet you at Jez' s and we will have a look :cheers:
You won't get that on a 2.6l unless it's fully loaded up :)
On the street it's around 4000-4200rpm in 3rd for a 2.6l if memory serves me correct
u are the first unhappy -5 customer I have heard...am I allowed to ask who is your tuner?
Add me to the list then for street/hill runs/motorkhana stuff the -5s are shithouse on a 2.6l
Cars was significantly faster with the smaller turbos coming on much faster in a on/off throttle scenario as -5s are lazy and need a stroker.
Interesting as I found my other gtr with -5s very responsive. That was a 2.6 as well.
What do u think is a good turbo for the application u refer to above?
Its not a loaded question- just like to hear your opinion.
Well given I've said many times over that I had -9s taken off to put the -5s on (so i can comment on both, unlike most)... Wouldn't say it's particularly difficult to come to such a conclusion :merli:
I've had GTSS, GTRS & -5's on a 2.6ltr (as well as -10s on a 26/30 which Paul has driven).
^ Absolutely you can comment on -9's back2back with -5's as you've had both...really is horses for courses though as I personally found GTSS's way too small (not sure how -9's compare to GTSS though)
I think it depends on the sort of driving you do. Guys that do the 'on/off/on' driving IE hillclimbs, skid pan work and track work will always favour the small stuff.
Steveo overlayed a 2.6 with SS's and my 2.8 with 5's and down low they were pretty much the same. Top end, well we know what happened.
2.6 with -5's is still lethargic, however peoples definitions of being lazy/lethargic/laggy are all different.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
