Cheers mate, i was looking into the kits last night coz i think it will be easier to just chuck in a 2.8 crank rods and pistons into my engine already as thats all id need to change instaed of going 3L.
you can re use the existing head studs and all that stuff right? just need new head gasket and bearings?
you won't regret going 2.8, I remember driving Paul's when it had the gt-rs's still on it and the bottom end torque was amazing, I actually made the comment that day "the only thing I'd change is put 2530s on it"
yeh in reality i should of done it when i built my motor 3 years ago.
its going to have a t51r strapped on the side of it so it should make it pretty fun ( not that its not fun atm lol)
We are still to sing whistling dixie down the freeway Chris! ;)
I know the feeling...done that!!
I always dummy fit first especially with new/modded/rebuilt turbo's.
It's too much of a pain to re-clock once they are in...
Well you would think when you took them down and said "reorientate to fit a GTR" you would expect them to fit!!!!!! :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: .
Bit of an update;
Got the turbos back this arvo, they said they were out by 10 degrees. Don't know if it was that much but they're fixed. The hot side is complete bar the turbo supports and one water line.
Tomorrow I pick up my balance tube and idle garbage from Hypertune. Too hard to explain so I'll take some pics what I've done.
wasnt it just a simple case of clocking the rear or front covers?
Not the point. I wasn't gonna sit there pulling shit on and off trying to get tr correct angle. I know what you're thinking "it ain't that hard". But with two of them that need to be the correct angle its a pain in arse.
Either way, how did it get messed up? Have a look at the 200 gtr turbos out the back and make it the same.
belt the crap outta it! be keen to see what the -5's can produce. Still got my dollars on the 470kw :)
Haha. It would be nice. I'll be stoked with 450 at a reasonable boost level.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
