I had the exact same problem. Under load above 4000rpm (dependant on load situation) both on road and on dyno (ramped, etc) when accelerated hard my car would have a miss and sort of hesitation. If i eased on the accelerator, the problem did not occur. We changed fuel pump, had all injectors flow tested, etc, as they are brand new, and car still hesitated (missed). I WAS running NGK platinum plugs (gapped to 0.8mm) and the car still had same symptoms (exactly like you are saying). I have super tech valves with titanium retainers, etc, 1.5mm overized valves stainless on intake and nitrite coated on exhaust. My springs are 95pounds at the seat and still car hesitating under load. Problem was found that my spark plugs were arching out under load. (Simple rule of thumb for old school mechanics - plugs up top, points down low) checked my coil packs, they were fine. Changed the plugs to v-grove and solved my issues instantly. Have also since put SplitFire coil packs and HKS plugs. I was running 12psi when this was occurring so had nothing to do with coil binding or a dud valve spring.
That's just my two cents. Hope this info helps.
I'll mention this when I speak to them today. Cheers for the input ;).
Paul I know you mentioned the timing looked good but might pay to call ross about the trigger kit a local company here in bris was having miss fire issues on there car and they traced it back to something in the trigger kit arrangement. Sorry this is second hand information so i dont all the details but thought was worth a mention..
We had what seems to be that issue you're talking about in 2011 when I put this kit on. The issue for us was the GT101 sensor was not PERFECTLY in line with the trigger wheel. New bracket has since been made. There's no logs of issues with timing or anything. When we had that issue we were seeing RPM logs of 86,000 RPM, 44,000RPM and would be hitting the RPM cut. Sound similar?
Again this is second hand info but they were talking another revision something to do with the cam sensor though.
I heard pauls testicles had shrunk so much he has started investigating plastic surgery to have a vadge grafted onto himself? Who woulda thought an electrician would have small balls?
On a brighter note, hurry up and launch it brah
skidz for kidz, or fatz maybe
Any updates on the strange miss yet ?... Want to see the figures this will put down in anger .
Sitting here with Yavuz in a hotel right now. Nothing happened today. As soon as I know it'll be up here. ;)
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
