So are you going to bring it to Texi in June?
And some of these expensive batteries, all it takes is one full drain to kill 'em. I had the same thing happen to my Red Top. Next time I'm just getting a big sealed unit from Big-W. Cheaper in the end even if I have to replace it every two years.
My current battery I bought one a UPS sealed jobbie off a guy here on the forums. Not bad, but could use a bit more current.
Wouldn't have been off WRXhoon?
this is the website/ebay place I got it from
http://stores.ebay.com.au/ALL-PURPOSE-BATTERIES-ONLINE/12-volt-batteries-/_i.html?_fsub=134846119&_sid=230461229&_trksid=p4634.c0.m322
they have actual store in Smeaton grange, go to the lithium batteries section in the left column, super start or ultra lite
the one I have I have let go dead 4-5 times now, I keep forgetting to undo the isolation connection on the terminal, charged it and take car for a drive and it's still working
and I most certainly want a ride in this monster :D
Talking to Yavuz today. He wants to try and squeeze 500 out of this setup. Airbox in place. He reckons there is a little left in it. Lets see how the little Turk goes. I don't think it'll get there
Inspirational
You may have to run this engine in operating hours
The amount of fuel Yavuz uses I'm sure it's safe. I have always said " I don't want it unless I can belt it around a track". It's not a one run screamer! That 472 is only after 9 runs from a totally new ECU. It's hardly "the finished product".
I Don't see why it won't be capable of 500rwkw
I had 1 2860r-5 on my sr and it made 251rwkw at Unigroup on 21psi dropping to 19psi and he thought itll make more power on more boost
SR versions are different to RB26 versions. We have a smaller rear housing.
I simply fail to understand this? 472rwkw is a sh!t load already.
Stop wasting time with the dyno, spend the money on new tyres, battery, diff or whatever it is that you need to drive it and enjoy it Paul!
  • Like 1
Farking Ditto !!
are the v-spec and non v-spec diffs the same width ?, I thought not cause I was expecting to change the CVs as well but I could be wrong
Some guys you need shafts, others say you don't. I'm a little confused myself.
When I get the housing and diff centre (this week hopefully) ill take it to Award and plonk it on the table.
You shouldn't need to do shafts, the diffs are same width hub to hub and the shafts are the same length.
Just finished sorting out A-LSD delete in a mates 33gtst using a non vspec gtr diff so had everything there to compare.
The sperm whale got strapped to the rollers tonight. Light load tuning of the E85 tune then Yavuz worked his way down to PULP. Final figure on PULP was 425 at 23 psi top end (25 early on). It was making close to 435 but he backed it off. Final cold start on 98 tomorrow, drain tank and one or two more runs on E85. Yavuz brought back the tune on E85 a bee's dick just to make sure it's a happy camper. He said around 460 it should make.
Pick up is tomorrow :D.
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
