I haven't really taken any mate. Car isn't at home at the moment. Are you looking at doing a twin 3 inch?
Yea mate, I'm doing a twin 3inch on my 32. I got AES building me some custom mufflers ATM, so I won't have any clearance issues, mine will be alil diffrent, as I'm running twin 3inch to the diff and than 4inch into the rear muffler.
Rang NPC and Exedy today. Exedy were pretty damn helpful. What I need is the dimensions and tooth count of this spline hub. They might have something off the shelf which might suit me to a tee and just plonk it in my casing. Sounds good to me.
Basically its tuned length front pipes, into a muffler where the stocker lives which has two 3 inch 'holes', twin 3 inch out then it joins into one piece around the diff. Not enough room for two pipes. Then back out into twin 3 inch, muffler then twin tips.
yeh those tuned length front pipes in particular is what I wanted a pic of, just to get a rough idea on how they went about em, as theres so many different ways to run em.
Cheers
Deano
Cheers
Deano
I know the rear one wraps over the front pipe. Makes getting them off an absolute bastard.
I just went through my photobucket, no pics of the fronts there :(.
If Exeedy can't supply a centre hub for your clutch to match your input shaft, they may be able to provide you with something that will be close. Ie, sharing the same number of splines, but a fraction too small for the shaft.
Given to a machine shop with a CNC EDM wire cutter, they could quickly re-cut the spline to suit your requirements.
I've heard similar good reports about the NPC carbon clutches too. Streetable etc. There was a guy up here with an 800ish hp R34 that used an NPC clutch to allow the holinger box to link up properly. My exeedy carbon D twin is taking some getting used too. It tends to slip when its cold, but get it hot just once and it holds really well. It would be interesting to know if the NPC's also have to be up to temperature to get them to hold.
I'll see what comes up in the next few days. I'll get the relevant info off PPG and go from there. Thanks for the info, Ian!
I had custom tuned length front pipes on my GTR years ago, it definitely kept the gearbox oil warm
And the heat that comes through the floor, esp passenger side. Jesus!
  • 2 months later...
Nothing yet, Eric. Car is still at the panel beaters.
Oil still hasn't been drained out of the box yet lol.
Michael Hill has given me his spare stock GTR box so hopefully over the Easter break I'll get it in then get my one stripped down.
I am considering putting a PPG dog set into a Getrag. The ratios are pretty sweet, even with the 4.11's, although would be better with the taller diff ratios.
You're having problems finding a center hub for the larger input shaft?
I had that problem when I went with the PPG dog box and larger spline input. Ended up going with a twin carbonetic clutch which has the optional center hub that fits the ppg input.
Edited by NismoSTune
That's good to know, cheers! What does it drive like?
I'm really liking this getrag idea. Does anyone know what tail shaft to use with the Getrag in a 33? I know you use the R34 front shaft but not sure on the rear. I'm assuming the 34 unit also?
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
