This was with
1) was with a straight bar removing clutch pack altogether, solid state lock
2) was over modified transfer case with the bolt in the back trick and 4WD controller
The key was not to over do preload and not have the controller turned up to high, this car had the 4WD controlled by the MoTec
So did you ever verify what clutch they recommend you run ?
In the end I just went the OS R3C. It will all bolt up.
Most guys I sent PM's too who run them over in the uk run the R3C too. Good enough for them, good enough for me.
This was with
Do you rate that bolt in the transfer case mod mick.
I've had it done on mine.. Car seemed to respond better in terms of traction
The spline hub is too small, Pete. :(
I knew that, NOT :)
Thats a shame, once it had a little torque it was not bad, even on the steepest hill here, the lookout, stopped and took off a few times and all good.
On a stock 32, yeah good cheap mod that works a treat, but it isn't as good as a modded and properly set preload and if coupled with the modded clutch packs and 4WD controller is a recipe for front diff failure/removal
What is the input spline on the OS88
It's the Chevy spline iirc.
An extra two splines and wider. That was the whole issue with the coppermix
Probably been mentioned before.....but did you look at getting the Coppermix centre machined/modified so suit?
I did look into it. I rang a few places to get the spline hub replaced to suit and got a few mixed answers. I wasn't really comfortable in hacking it up so I just got the R3C with the adjustable fork and release bearing kit. That way it will just bolt right in without a fuss.
I did make a thread on the pommy forum and a few guys run the R3C without issue. Good enough for tem, good enough for me.
Also, the coppermix has been in the car for 10
Years this year and hasn't had a rebuild/serviced. So at the minimum I'd have to replace the friction plates and have the spline hub done. It would almost be the same as buying a new clutch anyway.
  • Like 1
  • 1 month later...
Rightio.
After doing my head in the last few weeks, I have decided to return the car back to a standard state and move it along. The OS 88 hasn't arrived yet but i'll put that in the garage for a "rainy" day.
Rightio.
Wait what? You're returning the car to stock?
  • Like 1
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
