This would speed up the process ;)
Rightio.
I've been offered $19 K with a working head that has V cam. If it's not sold on here it will go to this certain guy, he just can't do it at the moment. So I'm not fussed if it doesn't move.
Might sound like a lot but
GT block - two on here for sale for $10k
Stroker - another $7k
Head cost me $11k
Marcus also sold his engine that was very similar just in a N1 block for $18K iirc two weeks ago.
Rightio.
Head cost me $11k
ah so Marcus finally sold his engine
Almost took him a year
Also yeah that's a lot Paul :D
Rightio.
Head cost me $11k
Try build it for that price though, good luck!
I bet your motor probably cost as much and you got stock crank, stock springs & lower than factory compression ratio and blowy poncams ;) Edited by Mick_o
Nup. My motor cost a LOT less than that lol.
Rightio.
Head cost me $11k
Paul it went for a fair bit more than that plus a stock engine and all gear to turn my car back to stock.
Wasn't advertised, just word of mouth and went to very appreciative owner.
What people don't get is that to get the sort of responsive power that Pauls engine has costs $$$ and time.
Anyone can build a peak power engine but to build one that gives you that nice big fat torque hit sorts the real engine builders out from the wannabees. Straight line grunt, pfft...you want a drivers car that gives race engine performance every time the loud pedal gets touched and will do it all day long.
You can bang your head all day arguing the point but proof is best kept to actual bum in seat feel but all passengers must wear a nappy as you'll soon get sick of cleaning shit stains off the passenger seat.
What Paul's planning now will be a very special and unique package and engines like these are far and few between because there are no short cuts, plain and simple they cost $$$, a lot of time and frustration.
  • Like 1
this ^ has now got me intrigued
Im gonna guess and say that he's going for RB 3.5, with GTX2863r with -5 comp housings, OS88 tranny in an R34 GTR
Yeah the next package will be pure insanity and super special i cant wait!
I can tell you from the drivers seat that the 2.8L is absolutely insane it free revs like an roadbike engine! A tiny blip on the throttle and the needle shoots off to redline as quick as you can blink! In any gear from 2nd gear and 4000rpm HANG THE f**k ON to that steering wheel as shit around you gets blurry and things start coming up REALLY fast!
Ive been in all kinds of wound up stock 2.6s and nothing is remotely as ferocious as this thing is! If you think that your 500kw 2.6L will touch this car you're dreaming as it just makes grunt like nothing I've ever experienced its sad to see it go as it really is a rare engine and theres definitely not another engine around like this thing.
  • Like 1
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
