In testing the Yaris Coil isn't as grunty as the Z33/R35 Coil.....
Any actual results for this testing? Everyone seems to rave about yaris could but can't find any solid info on the net
23 minutes ago, ActionDan said:
I thought it was just a head off situation for oil gallery mods or something.
I'll just send you my head and you can sort it all ;)
Good luck today btw,
Mine swings 50 degrees and I modified the cam from 8.7 mm of lift to 10.25mm. It won't fit. You need step 1 for a stock donk.
Quite possibly true however i'm not going for 1200 hp and i'm sure they're still good for the 800odd engine hp i want for mine
Only in-house for our own decision as to what coils we would use to build upgrade kits for the RB and SR engines. I'm not bagging any one using Yaris coils as they will be better than standard RB coils, but we found the R35/Z33 coils to be better.
I'm sure the Z33/R35 coils won't get you to 1200hp either, but we were happier with the strength of the Nissan coils over the Toyotas.
9 hours ago, Mick_o said:
Why are you blokes talking about coilpacks in this BUILD THREAD?
Lets keep the focus on this creature of the deep & more importantly when he chucks me the keys ?
haha, I think after all this time he will be sleeping in it for the first 12 months, lol
Here is one that might be OK for the coil info
https://www.sau.com.au/forums/topic/440409-ls2-coil-on-plug-mod/
8 hours ago, r32-25t said:
At least all of us twin fairies actually have cars that work :thumbsup:
Throwing rocks in a glass house ain't ya? How many times did your engine come in and out and drove a total of a couple kms? 5 I think it was.
:18_kissing_heart:.
This all started from the rear turbo packing in.
2-3 weeks and all good.
  • Like 2
:18_kissing_heart:.
This all started cause a gearbox broke,
I think it was actually 4 but that's in the past and right now if I want to drive mine I go to the garage and turn the key :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
