And I'm still waiting to be proven wrong, cause every time someone fits longer duration cams the bottom end power drops, which is tested very easily by doing a before and after compression test
so until the dynamic compression then increases again at their higher rpm efficiency level they will always be left behind in the bottom end
  • Like 1
I think that is the point I've always made - I don't recall anyone ever saying longer duration cams pick up torque at the bottom, be interesting to see if you have any reference or if you are just winning a debate against a made up side :)      If you can make the compromise (read: less VE) in a part of the rev range you aren't using then you just use the part where your VE (or "dynamic compression" as you're saying) starts building beyond what the smaller cams can provide, then you are always winning.   You wouldn't use 288s and a Promod94 Precision for a GTR used for hill climbs, you wouldn't use 256s and a pair of -9s for Pro-class in WTAC and you wouldn't use VCam and an EFR9174 for Pro-GTR drag racing.
I'm not saying bigger cams don't have their place, if want a 1000hp at the wheels then obviously you're going to use a fairly decent sized cam but then again at those levels response isn't at the forefront of your priorities.
What im saying is so many people are fitting bigger cams in the pursuit of better down low power and improved response, perfect expample is If you have an engine that has cams that still make power at 8500 and turbos that roll over at 7000 how is bigger cams going to be a benefit?
My findings come from many cars I have worked on from 6L na v8, 2.0 4cly turbos and down to 1.3L 4cly na engines. Even rotarys with their port timing will do exactly the same thing
Exactly.  Sounds a bit like you're arguing with yourself and declaring yourself the winner :D  The setup needs to match the other parts, most would agree.    I'm not aware of anyone fitting larger cams for low down power, though improved response within the target rev range... perhaps.
  • Like 1
2 minutes ago, ActionDan said:
Take it back to the cam thread.
I'll post in there next week when my setup is 4000rpm laggier for the extra 10 peak kW;)
OOPS!  Good call ActionDan, sorry Piggy.  If anything we should be talking about your low emissions cams and big laggy lightswitch turbo! ;)
Yes, that'd be appreciated in the correct forum :D
Couldn't fit the emission friendly cam in this time round. It's all in its box in the garage. Tackle that later on.
Lightswitch, laggy, snappy, unresponsive, slow to react to throttle input single is a goer but ?.
  • Like 4
4 hours ago, Piggaz said:
260 poncam strikes again ?.
What sort of grind did you decide on with Kelford? Lift at 50 thou (or 1 mm) and lift? Can understand if you don't want to release that info though ?.
Considered pulling the head off to relieve it and run more lift with a not so long duration?
The Kelford split cams (182S) I had in were 10.8mm lift so the head had to be releaved already.
New ones are as follows "We’ve just run some numbers and we can take our L182-A 260° spec and turn it into a 260° advertised (measured at 0.1mm valve lift with lash set), 226° @ 1mm valve lift and would be .406” cam lift, coming out at 10.00mm valve lift on the intake and 9.95mm valve lift on the exhaust after lash. At the base circle we’d need to cut them to, to try and ease the re-shimming process, you’ll be right on our safety limits of velocity and getting close to our nose radius limit, it’d be an aggressive wee monster and something I think would be a much better fit for your setup given your historic results."
There was an option to also drop to a 262 advertised with a 222 at 1mm and drop valve lift to 9.7mm but decided against it as they recommended the other grind
Edited by SimonR32
  • Like 1
11 minutes ago, SimonR32 said:
It's ready to go, just needs a tune... Tuner has been on holidays for a few weeks so waiting until he gets back and into it
Race you! I dropped my modified Cam off yesterday.
8 minutes ago, Sub Boy32 said:
Are we there yet....are we there yet....are we there yet?!?!?
Haven't heard anything. Not gonna be a pest and ask 4 times a day where they're upto.
  • Like 1
That's how a particular workshop tunes actually  (not the one your car is at).
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
