11 minutes ago, Piggaz said:
That’s sick.
Looking forward to whatbyou think about the efr with the “laggy big rear housing”. ?
Sadly won’t be apples with apples however will report back ( mainly with lap times)
same motor but upgrades include: valve springs, coil packs, crank kit to keep halal tech happy, dry sump and 4:4 diff gears
it better feel better
  • 5 months later...
I've seen plenty of videos, results look pretty bloody good to me!
Maybe he just got sick of some of the carry on that goes on in build threads?
Given how some people behave around here these days, there's much less of an incentive to share all the ups and downs of a build.
11 hours ago, Robzilla32 said:
So, what is happening with this build?
In the garage on the trickle charger. ?
Drive it every couple of weeks and just getting used to the box. Low speed, low rpm shifting without the clutch without making it go BANG/CRASH. Getting there ?.
Wont be touching it again for a very long time. The level of “over it” is very high.
With the 1.45 housing it went 517 AWKW, up from 486. Turbine speed remained the same at 122,000 RPM.
  • Like 1
The box is quite pleasant to drive to be honest, you just can’t drive it like a synchro box.
No need to justify anything lol. Could sit in the garage for all I care.
  • Thanks 1
Who gives a shit if the box is 5k or 25k and what the intended purpose was.
This is the shit I'm talking about, someone does something, anything, and people almost always go out of their way to tell the owner why it was wrong/wasn't what they said originally/not what their tuner recommended etc and straight away we're into hand bags and anti roll racing shit, again.
Who f**king cares, goals and opinions change, sometimes quite often and very quickly. Deal with it and maybe more people would post more info on their builds.
  • Like 2
Are you sad because you sold the AU? :(
  • Like 1
Hah, nope. Will be glad to not have to move it to the new house.
Am sick of what this place has become in the last few years.
I thought flat cap drifter f**ks had ruined it, but just as many GTR/Big build wankers with too many opinions and egos doing it just as much damage.
Lol I like to stir pigsarse up
but he is onto me and doesn’t bite
actiondan delivers though
yea baby
Surprised you have the time mate, thought you'd be too busy overcharging people for used GTR junk?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
