This was with
1) was with a straight bar removing clutch pack altogether, solid state lock
2) was over modified transfer case with the bolt in the back trick and 4WD controller
The key was not to over do preload and not have the controller turned up to high, this car had the 4WD controlled by the MoTec
So did you ever verify what clutch they recommend you run ?
In the end I just went the OS R3C. It will all bolt up.
Most guys I sent PM's too who run them over in the uk run the R3C too. Good enough for them, good enough for me.
This was with
Do you rate that bolt in the transfer case mod mick.
I've had it done on mine.. Car seemed to respond better in terms of traction
The spline hub is too small, Pete. :(
I knew that, NOT :)
Thats a shame, once it had a little torque it was not bad, even on the steepest hill here, the lookout, stopped and took off a few times and all good.
On a stock 32, yeah good cheap mod that works a treat, but it isn't as good as a modded and properly set preload and if coupled with the modded clutch packs and 4WD controller is a recipe for front diff failure/removal
What is the input spline on the OS88
It's the Chevy spline iirc.
An extra two splines and wider. That was the whole issue with the coppermix
Probably been mentioned before.....but did you look at getting the Coppermix centre machined/modified so suit?
I did look into it. I rang a few places to get the spline hub replaced to suit and got a few mixed answers. I wasn't really comfortable in hacking it up so I just got the R3C with the adjustable fork and release bearing kit. That way it will just bolt right in without a fuss.
I did make a thread on the pommy forum and a few guys run the R3C without issue. Good enough for tem, good enough for me.
Also, the coppermix has been in the car for 10
Years this year and hasn't had a rebuild/serviced. So at the minimum I'd have to replace the friction plates and have the spline hub done. It would almost be the same as buying a new clutch anyway.
  • Like 1
  • 1 month later...
Rightio.
After doing my head in the last few weeks, I have decided to return the car back to a standard state and move it along. The OS 88 hasn't arrived yet but i'll put that in the garage for a "rainy" day.
Rightio.
Wait what? You're returning the car to stock?
  • Like 1
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
