  • Replies 179
I am feeling a bit bored. Maybe I'll head out tomorrow night in rwd and give it a go. Need the practice. First time and all.
It's a bit tricky to get it off the line quick. It just wants to spin the wheels on stall.
if all geos well ill run this saturday see what it does very keen to improve on my old time
I would be keen too but I will have a car here to work on. :(
Tuning the 76 tomorrow night, I can already see there will be improvement, hopefully the top end is the same or better too.
Do it !!!!!!!!!!!!!??????????
Couldn't find you after Rudi, you must have Taken off. Well done on the pb.
For the first time, it was a steep learning curve! I lol'd at myself for doing single spinner burn outs. Oh well. :P
1st run was a 13.96 at 100 mph so I was happy to be in the 13s / 100s right away. Nice feeling. Second run was a mass of wheel spin off the line and a 14.8 lol. Tried too much stall.
Last and best run was a 13.84 at 161km with a 2.2 60 foot. Found that I could only launch with a bees dick worth of boost, like1psi. Otherwise it was just instant single tyre frying!
Look forward to getting the front shaft in and shooting for a 13.5.
Nice work guys!
Well done Alex on a 13 first time out! Time for that LSD and the front shaft; there's obviously a fair bit more in it with some stall and more traction. :thumbsup:
I'd really like to get out next Wed if anyone is keen; would've loved to go last night, but work gets in the way...
Thanks Dale.
Rudi, I parked up and went to watch some cars. Those ford turbos really boogy. The PAC rotor was good to watch too.
It was a great feeling reeling people in down the track. The start was slow, but all the cars I raced I reeled in down the track. Just the feeling like it was over so quick too.
Thanks Dale.
Good work Alex :)
2.2 is very good for a heavy car with a single spinner. Shows the 3.5 has the torque to move the weight.
