Hornsby are open till 12 on Saturday.
Parramatta I think are open Saturday morning also.
lol.. too late Paul, I got all my schizlle from Kudos. Got delivered within 2 days of ordering.
You bored on Sat? drop by LOL..
If I have a spare hour or do I will! :).
What a mission, only just got the box back on with 2 guys helpin, the car is also on massive 4WD ramps and 2x jackstands lol.
Turns out the clutch plate in there is still good, some piece of shit PBR clutch. I'm guessing the pressure plate is gone because of the uneven wear on the clutch plate hence thr total slippage.
Found a machining place $48 for flywheel, 30min wait.
Got about 600kms on my carbotic now and it feels great..rollin at 100 drop it back to 3rd and punch the gas .. Drop the clutch and it bites, HARD!!..
I actually felt sympathetic for the rest of my drivetrain ...
probably wouldnt do that too much... 3rd gear will strip in no time
ive blown 3rd twice now.. but i do drift mine competitively and its always on a clucth kick that it blows 3rd...
yep Ok :thumbsup:
I only did it once actually, just wanted to see how it handled it as the old one would slip a fair bit.. this one just "Thuds" into gear...
with the extra torque and e85 now, I rarely have to drop it back gears to get it moving anyway, just squeeze the gas, count 1 hippopotamus and its off...:D
I got mine back together today, last time i do a clutch on ramps and stands.
How is the pedal feel on yours? I think i might need to bleed the clutch fluid, feels like im pushing air.
I just got it done around lunch time, hopped into the car and I seriously thought I fked something. IT IS SO SOFT!!!!!!!
I honestly thought I didn't put the fork & pivot on properly, so I started the car and put it into gear, to my surprise everything was working!
You're right, feels like you're pushing air lol
haha awesome. I know people said it feels like a stock clutch but i was still expecting some fight, Its going to take some getting used to.
I know, it feels like the car is broken lol.. I've used GT-R Exedy clutches in my previous R33 and they were heavy as a pile of bricks, even with a larger Nismo slave. Let's see how this NPC clutch holds up. This car is stock atm, but that's going to change soon lol.
Was that a 34 box? I better stop doing that then :domokun:
Nice work Johnny!
It's not pretty Purple like mine :P
And my pedal felt alot softer with the NPC then the Exedy cushion button. Bites like a bitch, I'll always suggest an NPC to anyone who needs one
Yeah the NPC feels as if it's broken, it's so light for a sports/race/enthusiast clutch. I honestly thought the fork slipped off the thrush bearing and I was shtting bricks.
So far it's pretty good, unfortunately the R33 I own now is stock (for now) so I can't really punish the clutch.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
