Wrecking 1992 R32 GTST, previously registered, full URAS body kit, paint has a slight fleck/glitter, good for a re-shell, flared rear guards. Shell will be for sale, price will depend on what's left on it and what you want included. drp me a pm.
110,000KM R33 Series 2 RB25DET, tested before install by previous owner with good compression on all cylinders. It's believed to be internally stock. Has had timing belt done $900 (long motor)
R33 5-Speed Box – includes hd clutch $1200 or $1400 with the tail shaft and conversion for an r32 gts
Haltech Sprint 500 Platinum computer with unmolested lead kit $700
GTR Injectors $250
gtr head lights $200 for the pair
Aftermarket GTR Fuel Rail $100
Polished front facing intake (china spec) $150
Bigger throttle body $100
Big front mount intercooler kit with Turbosmart bov, TIG welded stainless piping (everything included) $300
Oil filter relocation kit $250 new
High mount stainless exhaust manifold, T04Z turbo, braided oil lines (needs water lines) $1200
Full 3" stainless exhaust with single Genie canon $300
Big alloy radiator $200, matching thermo fans $120
"Carbon fibre" look GTR style fibreglass bonnet $450
"Carbon fibre" look front grille $130
LED Tail lights $150
Smoked Reverse lights $120
HICAS removal lock bar $100
HSD Coilovers very good condition $600
Standard reshimmed LSD $300
R32 GTR seats $450
Turbo timer $30
adjustable upper control arms $250
Nismo control link set including castor rods, upper control arms and lower arms $500
Front strut brace $110
Rear strut brace $80
Everything on the car is for sale, so if its not pictured just ask and I will most likely have it.
pm me for anything you want
  • Replies 121
Fatz what cond are the headlights in?
want some with no chips/sand blasted glass, good reflectors inside, all rear mounts attached.
Price posted to melb? Otherwise i think Roy is in Sydney... wonder if that guy can bring them back to me
would have to have a decent look at them and pull them off
postage would be 30 bux
located ower blue mountains sydney
give jennas number a call if you want something as she is home all the time, knows what we have and ships everything (in between nappy changes)
pete (jennas number is 043189159)
Geeeeeeenuine T04Z Pete?
What rear housing, twin or single entry?
Cheers
the guy i bought it off said it was a garret but can't confirm until i pull it off and check
rear housing is a 0.88
id be keen for that setup since my td06 is out of puff but looks china spec. Exact same one on ebay for less than $600
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
