How much do you want for the front bar, indicators and grille?
I'd give you a call but lost your number lol
Honestly, I don't know how much it's worth. I had a look around on ebay/forums and it's about $100 for the front bar? Feel free to make an offer though.
Stinkypoo. Can I get that cannon from the 4 door? I'm assuming it has been welded already?
Only asking as my cannon has the stupid silencer in it as per recent thread.
PM me cost and location if you could.
Thanks,
James
I haven't removed it just yet but another person has already contact me about it. I will let you know if the sale falls through.
ONE OF A KIND - 1989 R32 GTS-T FOUR DOOR FOR SALE
Many hours and $$$$$$ spent to create this beautiful R32 rebuild.
Over 2,000 views in SAU Garage.
All receipts and rebuild history.
Very reluctant sale due to OS posting.
POA
CONTACT Robert Wilson - 0411 744 813 or PM
Stroked RB22 motor
Custom arias forged pistons and rings
ACL comp bearings
Balanced
Blueprinted throughout
Full block machine and relieved with oil restrictors
N1 oil pump modified
Crankshaft shotpeened,grubscrewed,oil collar fitted and micro-polished
Spool h beam rods with ARP 2000 bolts
Recon and ported head
Adjustable cam gears
Timing tensioner kit with gates belt and waterpump
Hi vol race sump with rear head drain
Cometic steel head gasket
Tomei 264 poncams
Tomei step 2 springs
Garret GT30/76 turbo
Intercooler
Custom catch can
650cc injectors
Splitfire coil packs
Z32 Air Flow Meter
Nistune ecu
Walbro 255 LPH hi flow fuel pump
Re-built four speed AUTO transmission with 1.5 torque converter
Pedders eXtreme XA Coil Overs
Hardrace Front Upper Adjustable Arms
Hardrace Rear Traction Rods
Hicas Lock Bar
Solid Rear Cradle Bushes
Slotted rotors with braided lines
3" exhaust with hi-flow cat
Vertex style body kit
King Wheels Camino Red 18x8
Federal 595RS-R - Front 225x40x18 Rear 235x40x18
Bare metal respray
Pantera leather seat trim by Alphaline Auto
Blitz Gauges 60mm - water temp, oil temp, boost
Momo Commando steering wheel
Memphis amp and speakers
Kenwood head-deck - DVD, handsfree, bluetooth
AWESOME :thumbsup:
Os posting? Your desperate to get rid of it.
Reluctant sale? The price is too high.
Good luck.
My guess is you wont sell it before you get back.
Edited by D.I.Y. Mik
Desmond Regamasters
Anyone in ACT after some nice light wheels?
rough tape measure offsets
17 * 8 +30
17* 9 +38
overall good condition, couple of scratches and minor rashing as per pics.
front tyres are 225 yokahamas with some tread
rears are unroadworthy
Looking for $1800
Located in Canberra
Pm for details
go here for more pics
http://www.sau.com.au/forums/topic/449305-desmond-regamaster-17x9-and-17x8/
  • 3 weeks later...
Hi All,
I have the following stuff to sell all pickup in Canberra / QBN.
Price is make are offer on here or via PM... I need this stuff gone i wont refuse!!!!!!!!!
Reverse switch (that controls the reverse lights) Brand new genuine nissan.
http://imgbox.com/xqypXZoU
Plastic Box for POD
http://imgbox.com/oFvc0G3k
Clutch and Fan. Clutch is stuffed!!
http://imgbox.com/THybj6ju
R33 s2 stock exhaust... all the way from dump pipe to back.. good condition
http://imgbox.com/l0c2GHWp
R33 S1 ABS pump... OK condition should work fine though never tested (i had a s2)
http://imgbox.com/eAV1Owii
R33 Emergency tyre
http://imgbox.com/bmxZHrPT
BARGAIN:
1X R32 GTR wing fibreglass black with 1 stud missing but good cond.
3x R32 GTR plastic side skirts with smallish (one pretty large as seen in pic) cracks (repairable) but no where mint. In black. 2 LHS, 1 RHS
Paid a bundle for these but.... they need a good clean and I CBF'd.
Price: 1 Bottle of Bundy + 4 litres of coke Zero for the lot.
As is where is. And, you must pick up in a Skyrine / RWD car and do a skid on way out :woot: .
Land of the free: QBN.
PM me!
6 Pack? Otherwise they are going to the tip.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
