NISMO!!!!!!!!!
gas cap cover
Dash gauges
Din gauges
Rear strut bar
Seats. Wish I could keep the fabric from pulling out of the plastic piece. They are old and used....guess I cant have everything be perfect.
Hood maul
restored the intercooler. SAVING NISMO! Who cares about saving NEMO, dumb fish!!
before
fins straightened
Fresh paint and polished up the end tanks! Me likey!
  • Like 4
Wow, that's really nice - much better than the damn stickers degrading over time like I have on my old bronze LMGT4's (I've bought replacement stickers in the past, but they sure don't last forever). I like it.
I look forward to seeing pics on the car.
  • Like 1
Nothing to crazy. Just some little tid bits.
Nismo license plate frame. Dry carbon with a clear coat finish.
Cool key chain. Was going to use it....but its to nice and kind of heavy. I'll just keep it in the box.
aUskYM8.jpg?1
a8xDEMT.jpg?1
WSKXD0S.jpg?1
Old skool registration paper carrier. I believe it's from the late 70's or sometime in the 80's. Great shape.
  • Like 2
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
