Nice parts Anthony, how hard were the seat covers to fit. Im considering getting a set?
a royal pain in the ass to fit. After you get the hang of it it's ok.... but it took around 4 hours.. 3.5 of which was on the front 2. The rear seat was easy.
  • Like 1
Well got a little update. The omori factory bnr32 inlet pipes are available. Mine were delivered today, but I am still about 3 weeks to a month from returning home to see them :( I don't understand why nismo called my guy and said that they were for install only and had to cancel my first order. I think there had to be some kind of mix up in communication or something. So all is well BNR32 people. I will get some pics up when I return home!
Can anyone tell me anything about these shocks? Came out of my r32 gtr but i dont think they are the factory shocks are they? They look as old as the car though. Nismo part numbers 56110-rn585 and 56210-rn585. They are made by KYB.
I wouldn't mind any information about these too. Might get my wife to translate.
How did they perform, although after quite a few Kms, any shocks may require maintenance?
Resurrecting some old posts. But I was under my (new to me) R32 GTR and found the same shocks. Any info on these? I've only driven it around town, but seems to ride well. Haven't put my stress on them. Was planning out a suspension overhaul in near future and shocks/springs vs coilovers was obviously on the list. Wondering if this should affect that decision.
Does it comes with some nismo goodies inside?
Comes with a shoulder strap inside ! [emoji3] was originally looking at the gtr tool kit but gave up on that once i saw the price !
I have more than enough snap on tools to fill this bag
Woo #1000 post [emoji3]
  • Like 3
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
