Id say that I would compete for the title of "biggest Nismo whore" in this thread, Simon can probably confirm haha
My recently acquired Vspec R34 has the following;
ENGINE
35]
NISMO OIL - AIR SEPARATOR
35]
NISMO REINFORCED TIMING BELT
35]
NISMO INTAKE PIPING
35]
NISMO INTERCOOLER
35]
NISMO INTERCOOLER PIPING
35]
NISMO ENGINE OIL COOLER
35]
NISMO ADJUSTABLE FUEL PRESSURE REGULATOR
35]
NISMO HI-FLOW FUEL PUMP
35]
NISMO IRIDIUM SPARK PLUGS
35]
NISMO RACING RADIATOR CAP
35]
NISMO R-TUNE AIR CLEANER DUCT
35]
NISMO OIL FILLER CAP
DRIVELINE / CHASSIS
  • NISMO G-ATTACK COIL OVER SUSPENSION
  • NISMO SUPERCOPPERMIX COMPETITION TWIN PLATE CLUTCH
  • NISMO FRONT AND REAR SWAYBARS
  • NISMO LONG HUB BOLTS
  • NISMO R-TUNE BRAKE PADS FRONT & REAR
INTERIOR / EXTERIOR
  • NISMO R-TUNE FRONT BUMPER
  • NISMO CARBON LOOK CENTRE PILLAR TRIM
  • NISMO CLEAR FRONT INDICATORS
  • NISMO CLEAR SIDE INDICATORS
  • NISMO “GT500” L.E.D TAIL LAMPS
  • NISMO GEAR KNOB
  • NISMO FLOOR MAT SET
  • NISMO METER SET – WHITE
  • NISMO M.F.D ( MULTI-FUNCTION DISPLAY) SPEC KIT VER.II
Plus, do the plates count? lol
And my daily R33 has;
Nismo LMGT-4's
Nismo Braided brake lines
Nismo Clutch slave cylinder
Nismo Super Coppermix single
Nismo radiator cap
That is cheating Joe.
You can't buy a Nismo promo car and claim nismo whorisim.
hahaha
Bahahaha sure I can, I would have had a list that long on the 33 if I had thrown the cash at that instead :yes:
Plus I harass you to sell me those rims EVERY time I see you lol
Nismo...
LM-GT4 wheels
Clear indicators (I think they are Nismo?)
600cc injectors
Competition Spec Coppermix twin plate clutch (awesome clutch thanks to Stevo-O).
Oil separator can
Fuel pump.
Fuel regulator... and
'Hoodie' jumper
Omori factory shirt :-)
nismo lmgt4
nismo dark indicators
nismo exhaust
nismo cluster
nismo floor mats
nismo ti gearknob
nismo fuel pump
nismo power brace
nismo timing belt
.......how is it all?....GREAT, except the exhaust which looks like a55 (and not the good kind)
still yum ^^
...and the thing about Nismo items (except for your exhaust if it has a 90 degree bend in it), is that you can take them off > sell them easily
Terry I put the exhaust up for sale with some other bits and pieces last week. Many expressions of interest for everything and few pieces sold, but the exhaust :/ Its the discontinued oval-tipped one...The guys over on the UK forums were selling them used for $1400 :O
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
