I checked your printout - sorry i cant add anything more with my limited knowledge. AFAICT its looks reasonable. Ask in the Vic forum what suspension place is recommended in your area. I've never got the service I was looking for in a chain like Pedders or Bob Jane.
Tyrepower ringwood seems to be the place to go, long history of perfect aligning. Makes sense, lower overheads from a smaller shop and less professionalism (cough bobjane massive wastes of space).
Will be dropping it off tomorrow so will see what they find.
I use them too.
+1mm per wheel station seems about right.
I just read that you have only 32 psi in 30 profile KU36s. Pump them up to 38 and try that. They don't work below 36 in my opinion. I run my 235/45-17 KU36s at 36 - 38. When they have fallen to 34 I start to wonder why the car isn't going where I want it to.
36 - 38 psi won't wear out the middle of the tyre either. I never have, over several sets of KU36.
Too much toe in not enough castor.
You want more like 6deg castor
Toe in zero front and rear
I am running 3 deg neg camber front and rear for the track but it turns in great on the street as well and no undue wear so far(4000km). Try at lest 1 -2 deg neg or whatever you can get with your setup
[quote name='R33-
Terry_GT-R34
Tyre pressure is? - 32psi
GTR-34A - Like i said they're brand new tyres Kuhmo KU36 18/30/265 all round,....
Is the tyre still rubbing on full right lock?
When tyres are cold, is there any improvement by pumping up tyres to 38-39 instead of 32?
Your profile is only 30 remember.
I was running 285s on a 10.5 rim with AD08s, never had any issues at all with tram lining in the dry. The car would jump around a little if there was a major deviation in the road, but any car will do that.
Wasn't running too much camber and just a good alignment from Racepace (their own mechanics do it), same alignment i had when i took it to the track, so it was all purpose and worked. I ran 32psi in them for street duties.
I did have alignments done by a few other places, everytime they just couldn't get it right and it would drive like rubbish. Perhaps give a GTR expert a go, rather than places that work on all cars? :)
That said in the wet it would tram line a little bit with such wide tyres, as the AD08s are especially wide due to a nice sidewall, however it really wasn't a major problem at all, even when i had 265 semi's on the car (was a little more squirmish in the wet, slight movement in the dry, overall still easy driven) :)
Tyreplus sorry, on bond st just down from barry bangay. or maybe he did mean tyrepower in croydon, but he said it was close. i'll ask again :D
Ash thanks for the suggestion although this place (barry) the head guy knows GTRs, and he said the printouts for the align match what he knows. I might ask for the specifics to post on here to compare, although obviously a 32 is different to a 33, plus all the other stuff you've done to your car :D
Would the fact my tyres are a starting to get low make a difference?
Thanks for all the responses guys - i'm going to get a third opinion by a one of the specialists recommended.
I'm tossing up between tyrepower ringwood or racepace
I'll post back results here once done.
  • 4 weeks later...
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
