Walk510. Stop posting in this thread. Im not interested in a Motec and your posts are of no relevance to this thread. Your posts are also impossible to read.
Thank you.
Guilt_Toy
What is the internal closed loop boost control like on the two ECUs?
Its great once you get it right. And, its exactly the same on both. VIpec=Link Link=Vipec..
  • Replies 100
dear kitto
your on a forum your asking peoples views and people are giving you there views i never said you should buy a motec i say you may like to compare them nothing more
if you cant handle someone s views maybe ring someone
these threads are just like a vipec bukkake session
Edited by Walk510
dear kitto
Your posts are like a motec bukkake session... :S
who the hell is walk510? and why does his posts look like that? im not even going to bother reading his posts.
i never use the closed loop boost control, some people don't like change or can be bothered with it.
dear kitto
I'm not having a dig at you. I'm just saying, i'm not paying for a Motec. But you seem to keep going on about it.
I created this thread so i could learn what the differences are between the Vipec and the Link and which one would be better suited to my application.
Yes i'm aware the Motec probably has more functions and capabilities but they come with a very large price tag.
The Vipec and the Link seem like very powerful units and well priced for what they can do.
Ah, so you just use a separate controller like a Greddy Profec B?
Any reason you dont like to use the closed loop boost control?
Can you clarify? How much work is it to get it right? ($$$)
This has been an interesting read as my YB Cosworth needs a new ECU to replace its Pectel. I just dropped in to the Vipec forum and it seems there is still regular questions about boost control, traction control, comms to PC issues and some sensor issues.
It still seems to be the go for backyard boffins who are willing to work through little issues to get reliably working.\
It can be a little fiddly to get spot on, but once you find the sweet spot in the duty cycles its brilliant. Never have to worry about any boost spiking.
You dont HAVE to use closed loop. You can just use the normal open loop boost control on the link. There is zero need for a standalone boost controller.
The reason i was keen to use closed loop is because in NZ as you all are aware it gets quite chilly :) And when it gets cold, the boost goes up.. the open loop wasnt holding the boost down to the level i was happy to run in the cold weather. But with the closed loop, regardless of the conditions it will boost exactly what you want.
Also in my case on the track (Rb25 + GT30 .82 internal), when the exhaust temps were getting up it was spooling up VERY quickly. The closed loop was struggling a little bit there, but thats because the internal gate is stupid :P And i wasnt keen to spend big money to go external. So on the track i turned it off and just run wastegate boost. Still plenty fast enough ha.
Edited by gotRICE?
Well this car is my daily and runs 26psi with an internal gate turbo so needs to be pretty good closed loop boost control as what is offered by the Pectel that it currently runs.(tuners and software for Pectel are few and far between)
Also, who is the cheapest V44 dealer ?
having spoken to a team member from NZ super tourer's team today i asked him about there ecu's
issues no data at all for 2 race meetings ,coms problems, engine temp sensor reading 110 deg C when it was really 80's due to faulty calibrations and there just a few
Issues like that are almost always wiring or user/setup issue rather than the ECU itself, they are pretty much all 100% the same, identical firmware, identical software, the only variables are the inputs going in and the setup/tuning of everything.
the temp issues were the whole pit lane i was told everyone was trying to get the engine to run cooler till they found it it was a faulty calibration ! rolls when your the control ecu of a series thats a bit of an issue
Edited by Walk510
a tool is only as good as the person using it. and clearly you and your "team members" have not RTFM, or have any idea how to calibrate an ecu whatsoever.
take your hating elsewhere.
"my flex commodore wont work with diesel, holdens are rubbish mate, i had to remove it and put petrol back in it ahhhhuhhhh hehha heeeee"
idiot internet trolls, why do i bother.
Someone stuffed something up then, its not a problem with the ECU - you seem to be adding a lot to the thread without adding anything useful, what are you trying to achieve?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
