There's also a ripper Asian foodcourt in Haymarket - Dixon House Food Court. Cheap and dirty food, but tastes sensational. There is one place in particular (I think it's a 'sizzling plate restaurant' or something like that) that gives mountainous portions - but be warned: they make their food HOT with a capital F!
We go here when we're in town for noodlesoups! There's one place that does a mean roasted pork noodlesoup!!
Hello niZmO person LOL
yeah I go there sometimes, but I miss the dirty ling long food at dixon, hunter, chinatown etc.. I do sometimes trek to haymarket for a dirty feed.
El Loco is pretty hipster too
$9 for a hotdog is a bit much, but it's not bad once a month. I work at Ultimo, so Essen is close by :D
Way to far to go for lunch.
Just came back from Crocodile Thai, that place hasn't disappointed yet. Decent prices as well.
should hit up Petaling Street a few stops down, awesome Malaysian food, without the Mamak prices & line.
Unfortunately I didn't see any croc on the menu :(
Maybe we should start a restaurant called, IF YOU DARE where the menu consists of
* Fugu
* Croc
* Gator
* Bull's Balls
* Pig's Trotters
* Ox Tail
* Locust in Chocolate for dessert etc
* Fugu
* Croc
* Gator
* Bull's Balls
* Pig's Trotters
* Ox Tail
if you're asian, 3/4 of that stuff isn't that crazy haha
* Fugu
* Croc
* Gator
* Bull's Balls
* Pig's Trotters
* Ox Tail
i tried all except locust...
* Fugu
* Croc
* Gator
* Bull's Balls
* Pig's Trotters
* Ox Tail
Man i eat half of that stuff with no fuss anyway - though i have not found gator on the menu around here - I ask some weird stuff in Thailand too, i didn't want to ask what it was... I just chewed and swallowed
cops trotters are the best, - The only thing i wont do is live bugs and fried spiders
a lot of this stuff is so heavily flavored/spiced you cant taste it anyway - good reason for it too :)
Ravi, have you tried "In The Mood For Thai" on the corner of Horwood Place and George Street, diagonally opposite the Roxy? I quite like it there.
Try Spice - the small place across the road from here. I think In the Mood is a bit "Thai by numbers"; Spice is good but not great (well compared to some of the places I like - Thai Potong & Spice I Am; I really like the shitty Surry Hills one if you can put up with the noise and don't want the ambiance of the others)
Place I LOVE in Parramatta is Temasek - best Nasi Goreng I've tasted anywhere in the world
Edited by Gunnar_11
Japanese: Belive it or not I find the best Japanese place is downstairs in Castle Towers, not sure what it's called but it is the one between Subway and the kebab shop. Apparently Eastwood is great for Jap and korean but I haven't tried them yet.
It's called ASAGO, for a second I thought you were talking about Midori next to Donut King.
Anyways I ate at InFlames Chicken in Castle Hill on the weekend and to be honest it's very over priced compared to anywhere in Granville or Auburn.
If anyone is looking for cheap good lebanese food, Jasmin in Auburn is probably best meal for your dollar. $17 for a mixed that that I assure you will be hard to finish!!!
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
