OK so any of you that know me know i have had issues with my car on boost, these were all boiled down to fuel delivery issues.
my car was cutting out round corners and running lean on the dyno over 5000rpm, anyway the culprite was my BOSCH 040 intank fuel pump, it was extreamly clogged, the mesh cover was caked and the filter was clogged, so i replaced it with a new one.
this one has been in my tank for about 2 months and it has fallen to the same fate, unfortunatly the Bosch pumps do not have a servicable filter and i assume the internals have been damaged anyway as the pump has become noisy again.
so im going to replace it AGAIN with something different, just for funzies. anyway obviosuly my tank still has shit in it.
i could get the tan kcleaned and try again but i am sick of going through pumps. i do not know if its just debris in the tank or if its rust from the old tank. SO
i have sourced a GTR plastic tank W straps, i still need a sender,
1st question......
with the larger GTR tank and new sender unit, what is involved in getting this to work with my stock guage?
i have also sourced some new gtr injectors (i already have these installed but they might be farked) new ones have been flow tested and cleaned....
what else appart from the fuel filter should i replacein the fuel system? any lines, any bottle neck which may have been affected by the crap going though my system?
https://www.sau.com.au/forums/topic/402153-fuel-system-clogged-to-shit/
Are u sure crap has gone through the system or just in the pumps filter and possibly fuel filter?
Mates 34 did the same thing. He ran the fuel in the tank through a fuel filter and into some jerry cans a few times to remove the debris from the tank. Hasnt played up since
well i have destroyed 2 fuel pumps, while i have half the system out i might aswell replace anything else i can, dont want to lean out pushing 1bar boost at 6000rpm again, bad sensation when it chokes
No offense but that
Seams like the worst answer. I'm happy to get a new pump and tank, do it properly, I'm even getting cleaned and flow tested injectors incase their not %100, why would I just keep going through pumps at $200 a pop and get rid of filters? I don't want old tank crap getting past the filters I want their to be no crap.
  • 1 month later...
I have a R34 with the same issue as the OP - Except I've gone through pumps in as little as uh, one day.
I was able to take the pump out, clean the mesh with it (Bosch 040) and put it back in and suprise suprise, it actually worked...
...until today, where it is again groaning and carrying on.
The above solution from Jez sounds like it's something to try, at $200 a pop, I can't afford a new pump every couple of days, but I CAN afford to buy like five fuel filters and some jerry cans and pump the tank through them and rinse/repeat instead of obliterating the mesh in the pump and killing pumps over and over.
Just cut the mesh out the bottom of the 040
Pump
And Just replace filter a lot more often.
While this sounds like the ultimate backyard fix, um.. would this actually work? Any thoughts? Its much, much, much easier to replace a filter in the R34 than the pump. (and especially the tank)
How often is often? 5k kms? Or is this option just madness?
Happy to do either or both, really, really tired of replacing fuel pumps.. twice a week.
Seriously. It is an utter bastard on the R34. So much so I'd almost rather spend $1200 on fuel pumps lol. I'll try the filter and jerry can thing and post here just incase some poor soul has this problem and searches the forums and finds this (like I did)
I removed the mesh on 040 worked well for me
No issues I did a filter on every service
5000kms
Just comes down to what your prepared to do
I cut mine off as I got sick of pulling pump to clean it.
Dare I ask what the best way of removing this is? I tend to replace the fuel filter when I replace the oil filter anyway (i.e every 5k kms), because it's .. right there, and costs like $10.
I've only cleaned the pump out, but never really attempted to cut the mesh.
Cant' you flush the tank while it's in the car ? Pull the lines out the bottom and bung up. fill the tank with a suitable solvent (I'm going to say ethanol) - but REMOVE the fuel pump first !!!!
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
