  • Replies 48
blew my high flow
spoken to scotty a while back so quik question
for factory replacment for power and close to factory boost
would the garret gt2871r
or the gtx3071r be better ?
recomendations
Heh bud....how's that kickboxing going!!! Still in some need of practice!
https://www.sau.com.au/forums/topic/403258-nm35-turbo/#findComment-6413452
Geez guys, give the poor bloke a chance to update us on what's he's done/not done to his car before you drive him away for another year, lol.
There was promises of amazing things & I, along with Ryan by the looks of it, am pretty keen to hear results.
Edited by Commsman
https://www.sau.com.au/forums/topic/403258-nm35-turbo/#findComment-6413650
Rofl.
I appreciate the anatomically correct shade. Well done Sir.
LMAO, difference is you can polish up stainless to make it look good..... :P
(opens the door for Aaron to use the techno viking pic yet again)
OT, 3071 won't be close to factory boost response... but would you really want to go smaller?
Edited by iamhe77
https://www.sau.com.au/forums/topic/403258-nm35-turbo/#findComment-6414377
Your "insult" is null and void considering your lemon of an attempt at Stagea ownership. With everything you fkd up on your old Stagea, having a go at me over the colour of my old Stagea is a pretty average effort, even by your standards :)
https://www.sau.com.au/forums/topic/403258-nm35-turbo/#findComment-6416152
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
