This is a heads up from Carbon Car Systems Blacktown; not just to anyone in Sydney but Australia-wide.
After the 1st of July, the W/s cost of air cond gasses will be going north by anything up to 600%.
If you were thinking of holding off until summer to regas your system, think again!
https://www.sau.com.au/forums/topic/403368-air-cond-regassing/
So, previously, what was it, $70-100?
$600 to regas?
Portable aircon and an inverter would be less.
Can then also remove the aircon system, weight saving bonus.
Any reason Terry?
Govt making it harder due to hazzard?
The gas used by Skylines (and many other cars) is "R134A"
So when current stock of that is used up by your supplier Simon, the cost of a regas at the moment which might be say $95 will go up to around $150.
The breakdown of the above, is part labour - part gas cost.
There will be a different substitute refrigerant available in late 2013.
Cost to be advised...
Story's been on the news.
The Carbox Tax genius' have worked out it takes "X" tons of Co2 to make a Kg of refrigerant gas, so the gas industry has to pay.
Guess who picks up that tag.
Yeah...
Do you have any idea about the next new refrigerant yet "G", in regard to....
a) cost?
b) efficiency?
I received some word that it was going to be less efficient than R134A, but that's just heresay.
I'm out of touch with these new gases Terry, but next time I'm dead keen to try Hychill in the 32's older system.
Trouble seems to be finding a fridge tech. out in the sticks who's willing to give it a try.
However I can remember when R22 and R12 got shafted. Exposed commercial freezer units had their gas stolen and sold black market style.
I'm certain these crazy gas prices will start this practice all over again.
Ah thanks for clarification Terry.
Can anyone explain why we need to regas a closed system?
There's plenty of potential refrigerant leaks in any car's aircon system.
First off would be the shaft seal at the compresor. It's a carbon/carbon seal plus a conventional fla seal but over time it's going to leak.
This is why you're asked to run the aircon for a short time every day, to keep the carbon seal lubed and happy.
The seal has to hold static gas pressure (approx 75psi) when the syetem is at rest and then down into vacuum when the system is loaded.
Next are the flexible hoses at the compressor. They're swaged over a hose barb but any gas will still leak slightly.
And finally the gas will permeate through the actual hose material over time.
All removable connections are flare metal/metal or "O" ring and are very trouble free.
The compressor in your domestic fridge is inside a sealed unit, there's no flex/rubber hose and all pipe connections are silver soldered.
The refrigerant in one of those will be there until something mechanical fails.
Hi Guys,
After the 30th of June 2012 I would presume any refrigerant that is CO2 depleting will go up in price I would presume. This is because of the Carbon Tax.
I would also presume a lot of other industries that are emissions heavy will also be charging more for their services such as Transport etc.
Kind Regards,
Daniel
Carbon
Thanks for the info.
I was never told to run it every day.
I will now though.
So are there any other gases we can use in aircon/refrigerator systems?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
