  • Replies 55
krawler - dont know mate u will have to ask them.
it was done at DYNO SOURCE a 4wd dyno and was just be re-calabrated a week before hand.
gavin sayed another one of his gtrs made 617hp on a engine dyno and on the dyno source dyno it made 387hp@awhp
and that car has the works done to it with a HUGE single turbo.
wouldnt mind seeing what it would make on another dyno, prob another 60hp all depends on the dyno and how it reads.
Looks like you had a bit of wheel spin - that's what usually causes the dips and rises.   It's the wheels gripping, then leting go, then gripping etc..
Nothing to be worried about.
J
Well it is something to be worried about actually, if this is what happened, then why didnt gavin tell melv and then dyno again. Surely wheel spin of any kind on the dyno would alter the final results significantly
What I meant was just because the dyno graph is up and down as it is, doesn't particularly mean there is something mechanically wrong with the car.
Only got to 3rd?? Err... Have you seen a dyno work before?
I'm sure there are many good reason as to why Gav did what he did. My car is going down on monday so I'll ask all your demanding questoins then.
Who cares what the graph looks like, it's an awesome power readout that I'm sure melv is happy with.
no erin i have never seen a dyno before fill me in
I think she's probably wondering the same thing I'm wondering... What do you mean "Only got to 3rd"?
Normally dyno runs are done in 4th gear. Thats because it is 1:1 (or at least, the closest to. I dont think all cars are actually 1:1) and gives you the most accurate estimate of HP cause you dont get the torque multiplication you get with lower gears.
So when you said "Only got to 3rd gear", it sounds like you are thinking that he revved out 1st, revved out 2nd, revved out 3rd and then gave up? I dunno, you're crazy as a coconut :headspin:
And the other thing I was wondering was why the curve has all the blips. Apparently due to RWD swapping to FWD as it lost traction (yay GTR!) but I was thinking if thats on an AWD dyno, that shouldnt happen... Unless the HP is only actually measured on the rear set of rollers and the fronts are just there so the front wheels dont just do some 200k/hour static burnout on the concrete? I dunno enough about dynos :rant: Anyway, if thats the explanation than I'm a bloody jenios (nb - you are still crazy as a coconut :headspin: ) :)
I would think that there was a calculation done to account for the fact that it was done in 3rd and not 4th. There was no doubt a good reason for this!
Mindflux, a cars power isnt determined by the top gear at top rpm! by the sounds of things thats what you thought...by saying it only got to 3rd....
Nice figure, but I do wonder about it being done in 3rd not 4th. Also i doubt those dips are wheel spin just friday i ran my cefiro up on the dyno and thats rwd and it didnt have any of those dips.. Nice figure though :)
suprised power delivery isnt that broad though seems pretty peaky, mite be due to the gearing though
Wheel spin is very possible on a dyno. It depends on the ramp rate used and the power of the car (not to mention the grip on the tyres).
If the ramp rate is slow, it may tend to spin a little. Happend when I had my car on the dyno, and then again with a R32 GTR when I was there.
I wouldn't say it is common, but it does happen.
J
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
