  • Replies 182
its a freeway dolphin vented bonnet i'll hopefully be making a mould and might sell a few as they are no longer avaliable...........
You bastard! I was looking at them a while ago, hoping they'd make a short run. Figured options these days started and ended with Masa.
Let me know if you start making copies... Very interested.
That's 2! ;)
Out of curiosity whats happening with these rear braces
I spoke to jase the other day...they have finished the order.....we are just waiting for the final delivery inn japan for distribution. As soon as I know more ill post it but it should not be to long from here.
Alrighty...
All 20 rear braces have been sent from Ox to my mate (Apparently Ox did ask the question if front braces would also be required) - I told them no!!
They will be split up into lots according to the states below and sent to the contact point at the top of each state's list:
VICTORIA
prince_skyline (delivery point)
IRONPAW (VIC)
Scotty NM35 (VIC)
SydSyd (VIC)
Ot1 (NZ) - I'll on forward to you in NZ (pm me your address)
NSW
jetwreck (delivery point)
WAGON BOY (NSW)
Mr 20Valve (NSW)
Commsman (NSW)
Howaitonaito (NSW)
Rosella (NSW)
Rudi ARX TURBO (NSW)
Daleo (NSW)
QLD
joshm35 (delivery point)
Dcdc (QLD)
LineitUp (QLD)
R6n350GT (QLD)
SA
bigkevracer (delivery point)
impul535w (SA)
Skipovalov (SA)
We are aiming to have these sent out by Thursday/Friday this week, so if there is any changes required to the above, please let me know ASAP. Craig has provided the delivery point addresses. I will get tracking numbers so they can be tracked and let you know. Should be around a 7 - 10 days delivery to the delivery points..
Edited by prince_skyline
Done - updated list:
VICTORIA - 5 pieces (incl. 1 NZ)
IRONPAW (VIC)
Scotty NM35 (VIC)
SydSyd (VIC)
NSW - 7 pieces
WAGON BOY (NSW)
Mr 20Valve (NSW)
Howaitonaito (NSW)
Rosella (NSW)
Daleo (NSW)
QLD - 5 pieces
Dcdc (QLD)
LineitUp (QLD)
R6n350GT (QLD)
Commsman (NSW/QLD)
SA - 3 pieces
impul535w (SA)
Skipovalov (SA)
Cheers
The rear Braces were sent yesterday (small delay as i needed to confirm phone numbers of mail recipients). According to tracking they left Tokyo today.
4 parcels as per the destination points above. ETA is 3-7 days (EMS), so may even receive them by Friday...
Tracking numbers are below:
VICTORIA - 5 pieces (incl. 1 NZ) - TRACKING NUMBER EJ185487589JP
NSW - 7 pieces - TRACKING NUMBER EJ185487592JP
QLD - 5 pieces - TRACKING NUMBER EJ185487601JP
SA - 3 pieces - TRACKING NUMBER EJ185487615JP
Track here (RHS of page): http://www.post.japa...s/index_en.html
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
