If you depend on it, it's a crutch. I'm not saying they don't work or serve their purpose, but once you start don't expect to stop.
Will probably do it myself one day, but prefer to hold off as long as I can.
See I dont think it is necessarily a crutch...
And thats why im seeing what everyone elses opinions are.
Imo a belt just allows you to apply more pressure when creating the internal 'belt' using your stomach.
If it allows you to squat 10kg more, thats your quads, thorasic, CNS, etc. all getting used/havin to that 10kg heavier load, yet you're still applying the same pressure, if not more, due to resistance of the belt.
  • Like 1
If you look at the strongest deadlifters in the world, they all wear belts during training and competitions, and I don't think they have weak backs! There is a strong (haha) correlation between those who wear belts and those who lift crazy heavy weights.
My thoughts essentially echo jangles.
And if you plan on competing, you may as well train with the gear you're going to use.
Im think im gonns start using the belt more once my back gets better and I can start squats and deads again.
Super bummed because I finally hit a 160kg squat and a 210kg dead and then did something to my back bending down to get something from the fridge :(
What sort of belt to you use?
Unfortunately, it's usually the straw that breaks the camels back.
need to work on my deadlift form. No pain from the lift but an experienced coach has pointed out a couple of flaws in my technique that he recommends me fix before comp day. Hopefully it helps me lift more.
not sure if link will work or if my FB account is on private or not.
https://www.facebook.com/video.php?v=10153230373749688&set=vb.598394687&type=2&theater&notif_t=video_comment
I find a belt a must for heavy squats. That said I squatted 180kg @ 88kg before I started using one.
I never used a belt for deads as I could never get comfortable. Until I realised I needed to loosen it and wear it much higher than when squatting. I now wear it around my upper abs/mid back, rather than down around my lower back.
If you can set your lats tight and fight the rounding of your mid back you can transfer more of that initial leg drive to the bar. That's where a belt can help. Once you lose tightness in your mid back all the load get's transferred to your lower back and you will have trouble at the top locking the weight out.
I don't see a belt as a protective device. Plenty of people have hurt themselves wearing one. They're just an aid to keep tight and not let an power leak out during a lift.
  • Like 1
Congrats on the squat nick
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
