  • Replies 60
Posted Images
tuned stock ecu for sale, tuned by KSP factory to suit r33 gtst s2 with turbo back, CAI, FMIC, 10PSI.
$200
Edited by xm4tr1x
Hey you still got the rear right tail light? Car is series 2 right? I'll buy for $70 you do
yer cool mate $70 its yours pm me for more info
onl
Hi mate after left and right front inner plastic wheel guards if you have them also keen on boot trim and diff if available.
Cheers
only diff available. from your list. $200
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
