Early tuning so far has cracked the 300kw barrier. Has a small misfire up top of revs, threw a new set of plugs in it to see if it helps ran out of time in day. Its still making power at 7400 revs so its promising so far
Gotta love modifying cars.
After taking car back in with new plugs and the thought missfire had been cured, ran it up seemed good to go did a few runs running spot on. Started to get some heat soak into Everything and it starts breaking down again......:(.
Looks like the set of splitfires have seen their day. ( they were on car when it was purchased do unsure of age).
Currently on 18psi its making 317kws which is getting there. Once coils are fixed ( very soon) it will be good to crank some boost into it
Just getting another set of splitfires. Owner thought about copying setup that's on my own car, 6 Bosch coils and aftermarket ignitor pack but plebt people making power no issue with splitfires.
Expecting power to jump up quickly from now. The turbo should be coming alive with a bit more boost
New splitfires arrived and are installed. Quickly threw it on dyno just do get a lot of heat soak in it and load it completely in 4th. No missfire.
Once workshop has a spare couple hours it will get put back on for attempt number 372865 at successful tune.
Sure do I'm over in Bargara, just about to start a little build soon but have bought fuel system components to suit 98. Might have to upgrade once it's up and running.... Good thread mate, very keen to hear how it goes once tuned!
Cool id say depending on project plan it out and spend once, otherwise just throwing money away. From what ive seen and heard the ethanol content is pretty consistent on a analyzer.
We are keen to get some results but it all just takes time unfortunetly
Yeah you're right, the Xspurt 1000's will handle it and I can just use my new intank pump as a lift for a surge tank so that will work out ok. If United remain a reliable source for good E85 then that will be excellent! Make sure you let us all know once you get a tune on ethanol as well :) be very interesting to see the same setup tuned on 98 then retuned on E85.
  • 1 month later...
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
