Ev's - R32 Gtr - Targa/sprint/hill Climb Build
Damn this thing looks good, great work, keep it up
I will try to keep it going, but cash is now running out. I now know what "R32 money pit" means...
She will be going to the track in November but it will be with a stock engine & drive train. These works will have to be carried over to the future stage 2 works.
I purchased a second hand set of BOVs from one of the SAU members and these will be fitted returning the cars BOV setup to stock.
RPM tell me that stock is the best setup and to dump the "trumpet" BOV setup.
Not long to go until stage 1 finished.
Plan to take the car to Lake Mountain in Nov. I have it entered so fingers crossed it gets out of the work shop.
Being an R32 its turning into a true money pit.......4wd fault lights, ABS fault lights......$$$$,,,,,more $$$$
Brake Kit QUESTION?????
I have Rays TE37 18x10 wheels. What is the biggest AP racing rotor I can fit?
According to some of the forums you can go up to 380mm rotor with TE37s.....
When I rang the ebay guy selling the AP racing kit he told me only 356mm rotor will fit the 18 inch rim.
Conflicting stories.....does anyone have the same TE37 rims and 378mm fitted?
taa
You have a few options. Assuming you are running an AP 6 pot from the 5000 series then you will be fine with up to a 380mm rotor. I would personally try and run something thicker than 32mm if you are going to be doing a dedicated targa car where you dont have the time to even detect, handle and live with any brake fade.
So depending what you are looking to do you can go for a setup you can either try and grab some R35 rotors and hats. You can grab some V8 Supercar rotors and get hats made up to suit a caliper of your chosing. Stoptech do a 380x35mm
But generally I would be looking at an AP or Alcon caliper that will do a 376-380mm with a thickness of 34-35.5mm. Inside a TE37 they will fit fine and still have clearance for rocks etc
Hey Roy, one more for you. I have been told that I need to purchase an R34 brake master cylinder for this big brake upgrade. Will simply replacing the master cylinder do or do I need the R34 brake booster as well?
The whole brake master cylinder thing is not that big a deal if you have ABS. Depends on what you are running now and which AP caliper it is you are buying. You have done well to find an AP kit for a GTR with that sized rotor as they are normally custom and not off the shelf AP with that rotor size :thumbsup:
You should ditch the booster, you will get much better brake feel. And you will need to run a R33/R34 Master Cylinder, the big rotors will give you a fair wack of pad knock off, and when your at the bottom of the mountain decent, it's nicer just to have to tap the brake pedal once to bring the pads back.
You sometimes get pad knock off on some kits but its definitely not the norm. I have never driven a Skyline without the booster so cant comment on that but the Catherham, friends App J Historic Touring car all felt great without a master. But they are light cars with little tyres, ;little horsepower with little in the way of braking capacity. Be interested to see how a Skyline feels in contrast, if it feels the same then great....at the end of the day if its a Targa car with ABS I say dont stress there are other things more important to mess with like suspension to get the car to stop
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
