Simon-S14 Posted September 2, 2012 Share Posted September 2, 2012 hey this 33 im working on i cant get it to run with an AFM plugged in at all.. runs fine with AFM unplugged but the min you plug it in it stalls and wont start, fires but wont run. has a known working afm on there and then tried the one off my other car. have searched for air leaks.. nothing found.. any suggestions? Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/ Share on other sites More sharing options...
discopotato03 Posted September 2, 2012 Share Posted September 2, 2012 When we fitted a Z32 MAF we had the outer two wires wrong way round and it was a bit like that . Is it std or been played with ? A . Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515209 Share on other sites More sharing options...
Simon-S14 Posted September 2, 2012 Author Share Posted September 2, 2012 Stock loom, stock Ecu. All that's been done is an engine swap Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515230 Share on other sites More sharing options...
GTSBoy Posted September 2, 2012 Share Posted September 2, 2012 Try another AFM. The faulty one might have cracked joints or a really dirty sensor. Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515296 Share on other sites More sharing options...
Simon-S14 Posted September 2, 2012 Author Share Posted September 2, 2012 Nah the one I tried works in my car but not this 33 Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515344 Share on other sites More sharing options...
AngryRB Posted September 2, 2012 Share Posted September 2, 2012 series 1 and 2 have different air flows i think, what colour is the tag? Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515353 Share on other sites More sharing options...
Simon-S14 Posted September 3, 2012 Author Share Posted September 3, 2012 Green sticker. Its a s1 loom and Ecu Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515465 Share on other sites More sharing options...
WMDC35 Posted September 3, 2012 Share Posted September 3, 2012 engine swap/conversion? was car running with these elecs before engine swap? not something unusual like ecu plug not pushed in properly? Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515544 Share on other sites More sharing options...
89CAL Posted September 3, 2012 Share Posted September 3, 2012 series 1 and 2 have different air flows i think, what colour is the tag? I dont think they are interchangeable however. Different plugs Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515554 Share on other sites More sharing options...
WMDC35 Posted September 3, 2012 Share Posted September 3, 2012 I dont think they are interchangeable however. Different plugs yeah, s1 green sticker 22680-02u00 5 pin plug (usually uses 4 pins), s2 pink sticker 22680-31u00 3 pin plug Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515635 Share on other sites More sharing options...
Simon-S14 Posted September 3, 2012 Author Share Posted September 3, 2012 engine swap/conversion? was car running with these elecs before engine swap? not something unusual like ecu plug not pushed in properly? Just another motor cause previous one blew up. Ecu check is next on cards Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515651 Share on other sites More sharing options...
GTScotT Posted September 3, 2012 Share Posted September 3, 2012 pin trace, my money is on damaged wiring Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515703 Share on other sites More sharing options...
Simon-S14 Posted September 3, 2012 Author Share Posted September 3, 2012 so frustrating. continuity test on the power, signal and ground wires all tests out ok, with the engine off afm plugged in its reading 0.5 volt on the afm... if i blow into the afm it goes up in volts to 1 volt ish before i run out of breath haha. when i crank the car it doesnt drop volts on the power side and on the signal sie it goes up slightly with the extra air its sucking in while cranking. tested both at plug and ecu. fine. im suspecting its possibly fuel pump at this stage. with afm unplugged and the fuel return line off the hose im getting no fuel coming out the rail when idling.. when i raise the revs some fuel comes out but then as i raise the revs til the point it cuts out with no afm plugged in (about 2500 rpm) not much fuel is coming out again. am thinking dodgy fuel pump, which is what caused the previous motor to blow. however why wont it run with afm plugged in?! Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6515875 Share on other sites More sharing options...
Dan_J Posted September 3, 2012 Share Posted September 3, 2012 (edited) with it unplugged the default maybe at certain revs to the so injector duty goes up etc so it just idles on the bad pump, when you rev more it leans out and stalls? just throwing ideas around also try unplugping the ecu coolant sensor Edited September 3, 2012 by Dan_J Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6516091 Share on other sites More sharing options...
DVS JEZ Posted September 3, 2012 Share Posted September 3, 2012 Does it blow alot of black smoke? I have an s13 just come into shop thats had an rb25 wired in. Similar issue's but choofing black smoke, found the tps wiring has 5 v to signal so ecu thinks its foot flat Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6516660 Share on other sites More sharing options...
Simon-S14 Posted September 3, 2012 Author Share Posted September 3, 2012 nah no black smoke\ solved it... its a f**ked fuel pump. got a mate to unload a can of areostart into the AFM while i was cranking it and it runs and revs as long as there is an areostart supply haha, fuel pump lacks pressure Link to comment https://www.sau.com.au/forums/topic/408401-rb25-wont-run-with-afm-plugged-in/#findComment-6516692 Share on other sites More sharing options...
