  • Replies 175
Pretty sure you have Long and I wrong in the results... I was running as 41 and he was running as 42. We stuffed up the numbers but stayed consistent. I was the one that WD'd the last session
So you two are simply in each others spot? If so, credit to Josh, you beat Thai.
well im happy :cool:
almost broke the 50s barrier on the long wang :ermm: no way
Pretty happy with my result :banana:
Now to try stay in the top 10 next deca!
:woot: So happy with the results!! Wooh!
You three did awesome. Jake.. you need a co-driver. Jett, you need a turbo car ;) Maaaark. 7th is damn good in your boat.
ps. in theory - i beat you all. Again.
Consistently fast times mate. You would have had another 90 points if you could remember where to go. Reality trumps theory though ;)
Bloody happy with my mega mini and long wang times! Next time I'm rolling on rims that aren't worth quite so much and have a bit more side wall :D
Whats this mean for the s13?
over all i am pretty happy considering i was driving a taxi... cant wait to see the difference in times when i bring my datto... Build update is i have got the new struts and brakes, castor bars and all i am waiting on is the control arms now... so close to ready yet SOOO far!!!
LOL yeah my brain is seriously cactus. I'm so excited when i nail a launch my brain goes "well you aced that, f**k the rest and do 4wd donuts"
I'm going to actually study for Dec. Watch out Mike/Ryan/Reon/Rollover - IM CUMMIN FOR J000!!!!
homo.
totes homo.
http://www.3news.co.nz/Australian-politican-says-beastiality-could-follow-gay-marriage/tabid/417/articleID/269838/Default.aspx
ERMAGERD DERKS!!!!
I might even be there in the R32 to wipe the floor with you and your 4wd boat. Or I might be in the drift car which means, WHO CARES! DOOORRRIIIIFFFFTTTTOOOOOOO!!!!!!!!!!!!!!!!!!!!!
Pretty happy with 22nd in the ute! Beat lots of Evo's, skylines and silvia's haha Did ok considering it's like 550kg heavier than the car I normally drive round at Deca lol. So much harder to change directions!
More importantly you won the burnout comp at the end!
Haha and a trip to Ford for some warranty work lol
Me - "Why are you scrubbing the rubber out of your guards?"
*watches Russ make a 5cm pile of rubber chunks on the ground*
Russ - "Warranty claim"
Me - "Yeah good luck with that"
P/S pump is growling at me. Something to do with 2nd gear RL lock to lock haha.
Last time I was 'getting rid' of some old tyres and the power steering pulley wheel snapped off. Got it towed to ford with the belts hanging out of the rear tyres and I picked it up the next day all fixed :) No bill :)
Have you had any issues with your diff Russ? A mate is currently having his fourth fitted (FG XR6T Manual Ute)
What's the issue with his? Is it lowered? I've got a humming noise between 105 and 110. No problem above or below. It's done it since I lowered it. I've just ignored it.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
