Ive got a gcg highflow ball bearing turbo on an rb20 I have 3 inch full exhaust, fmic, its running 10psi. It just starts making boost around 4000rpm and reaches full boost around 4500rpm. Was just wondering if this is normal for this setup or is there something I can do to change this
https://www.sau.com.au/forums/topic/408874-gcg-highflow-turbo-on-32-laggy/
Check that you have enough preload on the actuator.
How could I check the preload on the actuator?
And its a standard ecu
Move the push rod on the flapper or remove it and make sure there is sufficient effort to get it back on.
Also, is it a bush bearing highflow Or ball bearing?
if it has an adjustable turnbuckle on the waste gate adjust it in ( smaller in length) by half a turn and go for a test drive and repeat
could also be bad cam gear timing ifs its been touched recently
Edited by Dan_J
its a highflow rb25 turbo so bigger twice over than a standard rb20 turbo, I'd expect it to come on around then
winding up the actuator with stock ecu is a very bad idea as it will raise boost once
the correct pre load is reached
if you do it drive very carefully and watch your boost gauge
as soon as it starts to run more boost wind it off half a turn till you tune it
Edited by 1400r
i used to make 10psi at 4k with a s2 r33 front/ 0p6 rear trubo on the rb20 with the stock smic
for the gears, just confirm so its not a tooth or 2 off, the dot on the gears should match up with the cam gear cover backing markings
double check cas timing
stuffed cat?
if its just turbo lag you can get adjustable cams , retard exhaust and advance intake
shorten cooler piping
tune
A photo of the turbine wheel would be good. I've had few of their high flowed units came in for service, they were carried out using factory bearing housing, with cropped TA34 turbine wheels. if that is what you've got in your Rb20det high flowed turbo then yes it will be laggy, how ever it should be ok top end wise.
turbocharger configuration for Rb20det needs to be treated as a Sr20det, Turbine wheel to any thing above the size of a 2530 will feel laggy.
^^ im sure you would lol. The most fun to drive rb20 i've ever been in had a standard turbo , it was rather stripped of anything that wasn't necessary . People place too much emphasis on bigger turbos and expensive things to make their car faster , without doing the easy free stuff first! . I remember an interview with the late peter Brock and listening to him explain how he took like 30kg out of his Torana just by shaving all the excess off every bolt on his car ... My point being , that turbo has probably made your car slower over all , what hyper gear said about rb20 being similar to Sr is somewhat true , for street duties i don't think you would find much better than a 2871r or high flowed std 20 turbo .
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
