I don't get to drive my toy much but noticed soon after buying it that it was VERY fuel inefficient. When I say very, I mean absolutely appauling. People say yeh it's because you drive a GTR with aftermarket turbos, well yes, average fuel consumption is somewhat expected, but I am only getting 180-190 km per tank!!! It's actually laughable (and cryable for my wallet!). What mileage is everyone else getting? Please state your engine, ECU, turbos, and injectors as follows:
Engine: RB26DETT
ECU: Apexi Power FC D jetro
Turbos: Garrett -5s
Injectors: Sard 800 cc
Cheers.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/
RB26DETT
PFC, nismo AFM's
-9's
555cc
Around town, 400-420km
Hwy 100-110km, 550km
I use 5th at 60-80km and 6th over 80km.
Some people I've noticed use the wrong gear for the speeds they do, ie 3rd gear at 60km..... you think they just want to be ready to boost off or something.
All you do is wear engine quicker and use a gut load more fuel.
There is using the wrong gear like 5th at 40km/h up a hill, but come on!!!
O2 sensors seem to be a common culprit, and also lazy tuners that don't spend some time tweaking the light load/cruise map, and you end up with poor fuel economy.
Shouldn't matter what size injectors that are used too. I think ecomony matters as it = more fun km per tank :D
And Michael, geez that is like E85 fuel economy!!!! That ain't right!!
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6535961
RB26DETT
PFC, nismo AFM's
-9's
555cc
Yeh I know!! I spoke to Chris at Racepace and he tells me the injectors I've got are one culprit as is the PFC d'jetro which inherently has to be run richer. I get a buttload of unburnt fuel literally spitting out of the exhaust at idle :/ Apparently the guy who tuned it in Tassy wasn't familiar with the power FC (which is clearly evident) or confident in tuning it, but I didn't think it was possible to have THAT bad of a fuel economy.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6536038
See if its still running 02 feedback if you have a hand controller for your Power FC. If so then it could be your 02 sensor(s). I'm not sure how they work in the GTR's (There's 2 of them in a GTR right?) so if ones stuffed and ones good I dont know what this would do to the cruise AFR's
If 02 feedback is off, Then its possible that your cruise AFR's werent tuned or werent tuned properly. I have mine tuned rather then running 02 feedback because I can run it slightly leaner at cruise AFR's. The Power FC, I think aims around 14.5:1
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6536317
I've had PFC D Jetro on this one and the previous > both gave me 400+Km/tank ie more accurately 14.5l/100Km and a bit more with squirts (but not peak hour traffic)
State of tune was tops on both cars.
Both run 600cc Sard
Both run -7 or N1
Methinks your consumption is excessive, so 02???
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6536440
Engine: RB26DETT
Turbos: Garrett -5s
Cheers.
as i ask in every fuel economy thread like this, how many Litres are you calling "a tank"? without this we can't tell whether you just have bad economy, extremely shit economy, or a dodgy fuel gauge
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6537539
A full 34 GTR
A full 34 GTR tank which i think is 50L??? I think you could definitely regard it as extremely shit economy - Its about 23L/100 km :/
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541301
Just to rub it in a bit more I got 404kms today on 48L so 11.9/100 and that included an hour on the dyno which spent quarter of a tank on the gauge.
Was going to get wideband to tune for economy but don't think I will bother.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541319
A full 34 GTR
It's a 65 litre tank, but I have managed to fit in 55 litres when the fuel light was on for a while..... :whistling:
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541461
If the economy is that bad, you may as well switch to the E-flex and retune with a better tuner...
I was getting 450km average on 98
now getting 300-350km out of E-Flex
when the light comes on i have about 10-15Litres still in there, have measured 10Litres when its below the empty line..
Edited by SliverS2
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541612
Do you have a copy of your d-jetro map that you could email me? ian @ isit.net.au
I use a d-jetro and see around 180-200km/tank if I drive like a nutter. Best on the open road is close on 8-8.2lt/100km now.
Have you adjusted your cam timing with gears? If so, what are your new settings.
What is your cruise speed and gear generally...?
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6542187
You guys have me starting to worry about fuel economy because at best I get around 15l / 100km and it is not difficult for it to drop to around 21 or 22 when you really start to push it.
I still have the original o2 sensors in the car so it looks like they probably need replacing.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6545118
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
