Its not the gasket.
My guess:
It is an oscillation of the diaphragm, because the setup is different on a gtr, the pressure settings for open and closed arent right for gtst.
The throttle flap is much closer to the bov on rb25 and 20, so it would react different when you shut the throttle on an rb26 with throttle bodies closer to the head.
This is also relative to where the bov activation hose is located.
So its probly a pressure wave that is going just the right distance (or wrong distance cos its not right) to make it open and shut so quickly.
Never thought of the Proximity thing. Good thinkin' Mik.
And yeah, It's not Gasket flap. I reckon the aged spring and diaphragm gets the vibes and gives out the Frooty noise. Some do it, some don't.
Still reckon the GTS-t Bov makes for better throttle response anyhow.
I've been running a GTR BOV on my 25Neo for a few months. When it first went on I was sufficiently amused by the farty noise that it took me a while to realise that the car no longer felt as peppy coming onto boost as it had been before. Swapped back to the RB20 BOV (that's what I was using on my car since the Neo transplant went in, they're supposed to be the same thing anyway) yesterday. In my very brief unscientific testing since, I am sure that the car comes on boost more briskly with the little BOV.
It takes more finger force to push the GTSt BOV valve open. I'm not sure what that means. I haven't fully thought through (or done any testing against a vaccum pump) to see what it takes to make each of the open to know whether one being open more that than other of for longer as post turbo pressure starts to rise is enough to make the car perform differently. I suppose if the bigger GTR BOV is open until later in the accel event, then it will waste more pressure back to the turbo inlet before it finally shuts and therefore soften the boost rise rate.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
