  • Replies 47
Hey Mate, interested in the following parts if you still them and happy to post to Gold Coast QLD.
front grill from between headlights $30
headlights $150
Let me know Cheers
headlights $150
Let me know Cheers
both items already sold.
  • 4 weeks later...
cat back exhaust 3.5" - two large mufflers for very quiet operation with good flow (was flowing 390kw) $500
computer Vipec Pugin ecu with optional (external) 4 bar map sensor $1300
RB25 gearbox - rebuilt with all seals, bearings and synchros replaced 30,000km ago (Have receipts) $1700
dif - stock shimmed up to lock $150
coilovers Tien HA $600
adjustable upper suspension arms front and rear $200
brakes inc disks and pads (RDA Slotted, EBC red R + Yellow F ) $400
hicas lockbar $50
intercooler 600x300x100 with piping to suit 3L greddy $120
Stock seats - drivers seat has usual tear $100
nissan floor mats $100
copy gtr wing and bootlid $200
front 1/4 guard L $100
front 1/4 guard R $100
S1 Bonnet $100
S1.5 Front bar $75
Rear bar $50
doors (each) (no speakers or door cards) (pair - 120 each) $200
S1 non airbag steering wheel $50
Gauge cluster (217,000km) all gauges working, white LED lights. $75
dash pad $50
steering rack $100
power steering pump $40
alternator $80
aircon pump + condesner (neither have been used since 2007, probably needs new seals) $50
headlights $150
17x8 + 17x9 Nismo LMGT2 (federal 595 RSR Semis fronts 80-90%, rears on ind) $1100
brake lights $100
light up skyline rear garnish (lights up RED) $150
plain skyline rear garnish $40
Custom Fiberglass sub box (to suit 12" sub) $150
space saver spare $30
brake master cyl $30
clutch master & slave $30
52mm thick alloy radiator with 16" thermo fan $150
Bosch 044 mounted on bracket for intank install including speedflow fittings $150
front Strut brace (Apexi) $100
Starter motor $50
Ignitor $50
stock coil packs - working, spark broke down above 350kw $150
Jim berry full monty - spring centre ceramic button clutch $500
door cards front and rear $100
Castor rods
Handbrake setup
Stereo Brackets
anything not listed or not crossed off is still for sale
  • 1 month later...
  • 1 month later...
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
