RB is supposed to be race bred, numbers denote the displacement, d is dual overhead cam, e is electronic fuel injected, and the t/tt is presence of turbo or twin turbo. At least I'm pretty sure that's it.
That "RB" thing is an internet myth. Almost like calling an SR "super rocket", "super race" or something.
Considering the RB20 was the first of the RB's, I wouldn't call that "Race Bred".
Phonetically, aren't our grandkids going to be farked up learning that...
A stands for apple but
B stands for gasoline using cast iron...
yaddayadda ..... and....
R stands for nissan in line 6????????
:P
... not to mention the missus is going to flame me by sayin', "What the hell are you teaching that kid???"
  • Like 2
:P
They are already doomed with their fancy beedy eyed robots, 3d printers and levitating hats... "Back in my day" "shut up grandad, why don't ya warm the globe more" they'll say.
Yeah, well, at least with those, they don't have to ask (on a car trip), "Are we there yet?"
hehe...
After a bit of google looking R is a nissan inline 6 cylinder engine and the B is gasoline using cast iron/nickle based block, apparently? and S is 4cyl
I think RB etc are just the engine family. If R was inline 6 then it doesn't make any sense for an SR to be named as it is, same goes for B being gasoline/cast iron/nickle block then what is a CA? They probably stem from some internal codenames used for engine development.
Yea true, I retract my comment.
the R in SR could be aluminium block, hence VR38DETT???
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
