  • Replies 3.5k
Riders On The Storm [Fredwreck Remix] - The Doors (ft. Snoop Dogg)
one of the best experiences i've had in my car involved this song, a drive back from DECA, and a thunderstorm travelling in the same direction and speed as i was. 115km/h meant no rain, 100km/h meant storm caught up
Hahahah that's awesome! :D
