https://www.youtube.com/watch?v=-nYHAOL-Ihw
Interesting, I can't get the link to show the image etc is this the end of youtube links?
It is a guy called Eyal Raz and the song is called 'So Clear'
  • Replies 3.5k
37 minutes ago, BK said:
hey ben we must think alike this is my favourite band. anyways devin townsend hes good shit too.
DEVIN TOWNSEND PROJECT - Deadhead (Live at Royal Albert Hall) - YouTube
Absolutely, definitely one of my favorites bands to play - a completely underated band of very talented musicians. Don't know how much you'll hear from them now the guitarist Johan Reinholdz plays for big band Dark Tranquillity.
I like your link to DTP. Devy is cool, one of the great Canadian exports especially in the SYL days.
I'm in one of those moods so here's a much needed Australian pressure relief from Melbourne to clean out ones eardrums. One of my favorites from going to gigs in the 90s from the album Do not spit. Recorded at the Tote from memory - you'll work on your car at twice the pace !
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
