Hey guys,
Recently done the bottem end bearings in my 34, and just looking at my options,
Im looking for either a complete R34 GTR engine or just the head/block and ill swap all my parts across to the new engine.
Any suggestions on who might have engines in stock and rough prices? will also be interested in buying a Built engine if anybody is considering selling or knows of one for sale.
Otherwise Im looking at about 10k for a racepace rebuild, or 14k for their 2.8L rebuild.
Im not the best with engines so anybody able to give me a rough rundown on parts needed for a proper built 2.8l build with necessary supporting mods and price? HKS/tomei if its not a huge price difference from other brands
Thanks guys
https://www.sau.com.au/forums/topic/411100-looking-for-r34-gtr-engine/
Well the racepace 2,8l kit is everything needed for the engine bottem end oil pump and few necessary mods to the head, Then ill need to get -5 turbos injectors fuel pump AFM's and bigger front mount i think, for about 400 awk.
I can just about sell my -7 for same price id buy -5 so thats not an issue, So will probably set me back 14 for build and 1500-2000 for other parts.
but is it worth 16k for 400awk
And i keep hearing really big prices in build but i dont quite see where the value is.
even for tomei 2.8k its about 6k oil pump water pump 2k, machine shop 1-1.5k? gaskits and such another 1k? not sure whats needed in the head, but im guessing and probably missing some items of note?
Edited by itsmeyo
Hey guys,
Thanks guys
I've got a a mate with a whole 34 GTR engine for sale. PM for his details. Also, you can pick up the 24U N1 blocks for about 13k brand new....even less if your lucky.
Hey guys,
Thanks guys
Just out of interest, what are you going to use the car for?
Street, weekend car / Track beast? Or simply rebuilding it to get the car back on the road?
Are you pursuing big power?
I am going a head with their Stage 1 rebuild.
Smart stuff spend 1.1mil Yen (14k) on an overseas engine as opposed to 14k locally and at least have some level of recourse if something went wront :rolleyes:
cheers mate always a good idea to have options hence the 3 links I posted up
although I know most local tuning/building shops get it right first time
I've already asked Jesse about sending an engine over and he says his only container contact is in Brisbane so if you're in other states, domestic shipping costs would apply.
The engine is only able to be shipped via container so there'll be no tracking, no insurance, cannot avoid import tax, will take A LONG time and will set you back 14k when the Racepace stage 1 build will cost 10k and produce a reliable 400kw.
Well if its built right i guess i wont mind taking it on the track, but thats not what im doing it for, pretty much just playing the hand ive been forced now that bottem end is gone and would not mind more power.
But in saying that, it is my daily and i do want to be able to pass EPA without having to do Major work to do so.
I see!
I too was in a similar situation as it was just my weekender and was leaning towards just rebuilding it with stock Nissan parts.
But Racepace justify as you are not far off (price wise) a forged build vs a stock build.
+ while the engine is out, you might as well go with forged.
Also Racepace build the RB26 to their specs from what they saw best with their research and development.
So you paying $10K - $14K is not just an engine but along with all their further developments / improvements.
Emissions is not a worry as Racepace can easily fabricate to suite your needs.
^^ This!
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
