So basically car won't start, turn over, nothing, even when trying to jump it starter won't crank at all. The other day (Sunday just gone) it was slow to turn over, started fine in the morning then progressively got slower till it barely started, so i parked it facing down my boss's driveway thinking if it didn't start i could let it roll down and effectively push start it, without the pushing part lol. when i got in that time it started perfect, full normal crank speed. then was starting ok since then.
Missus goes out to her mates today, and i get a phone call half way through my after work grandpa nap saying the car won't start. and that it didn't turn over at all. so over there i drive and try jump it off her car, (little getz but have used it when my old battery was rooted) and still absolutely nothing. so we had to get her mum to come pick up her and bub and bring them home.
Any thoughts on whether i'm on the right train of thought, or anything else i could check, checked all fuses, and engine bay connections i could see while i was there. and battery is only bout 4 months old.
https://www.sau.com.au/forums/topic/411250-soi-think-my-starter-motor-has-died/
Yep probably the starter. They have a large solenoid (electric switch) that triggers when you turn the key to start, you should see if it clicks.
If you feel brave, pull the starter motor out. Hold it firmly and apply 12v. That will tell you if it is starter motor or some kind of wiring/trigger issue.
In the meantime....park on hills ;)
I had that problem a while back. No starter, could not jump. Battery seemed fine when tested with multimeter. Ah Ha! alternator stuffed. $120 later still stuffed. The battery was one of those sealed type with windows. If the green one showed up the battery is supposed to be OK. But it only says that cell is OK. Measuring the static voltage was 12.7, but when trying to crank SFA. New battery fixed problem.
How old is your battery?
yeah battery is one of those with the green light, only bout 4 months old but alot smaller than the one that was in there originally, they assured me it would be plenty big for this car as it's what the book says for skylines, i dunno. not feeling that brave with the starter, definately didn't hear it clicking,
earliest i can get into auto elec is monday, which i guess isn't to bad. was thinking i might get some mates 2morrow arvo after work or on the weekend to see if we can push start it to confirm it's not the motor or anything, ie if the motor runs fine then it must be something to do with the starter.
I'm with Hugh on this. I have had very similar issues as well. Battery was the problem. I can't explain the technicals but apparently some of those batteries do not charge properly and so it will go flat. When driving it may perk up for the next startup, but if left a day or more the grunt is gone. Jump starting a dead/faulty battery with a good one gives mixed results too because it is hard for the good battery's current to flow well through a half dead battery.
Simply remove your suspect battery and replace it with someone elses as a test. Won't cost a thing and then you can rule it out. Battery's can even get bad connections internally to the terminals and so random results occur.
Hope you get it sorted !
Just on batteries. On the RS4 I now use two Advance Power gel batteries as used in Aircraft Had them in for two years now no probs. I used two to get the required CCA and was the only way to get this when fitting the forward facing plenum. The batteries are fitted L shape in the normal spot as I ran the FMIC pipe thru the battery support. Incidently the two Advanced Power units were about the same price as a normal 660 CCA acid type
mine used to have a 40-series battery
pretty sure you can fit a 60- series no worries
soemthing along the lines of this fits well (same width as the stock tiny one but wider and more cca) :http://www.supercheapauto.com.au/online-store/products/Century-Car-Battery-NS60LS-430CCA.aspx?pid=287272&menuFrom=70701#Description
the spot in there is huge tho, so you could probably whack a dunnydore/falcon battery in there with ease (and a new tie down)
get the car going and whack a multimeter across the terminals, if its not up near 14v then your alternator is screwed
so i've tried a new battery with a much higher cca than mine, both via jumper cables (disconnected my battery so straight to my cars terminal leads) and then swapping completely and bolting my leads onto it, with the same result. Car doesn't turn and starter motor makes no noise whatsoever, not even a single click. gonna try a push start when my mates finish work and see how that goes.....
The same scenario happened to me and turned out to be the starter, trace your positive battery lead down on the left of the engine block, biggest cable of the positive side should go straight to it, once u find it try giving it a few knocks with something hard like a wrench this can loosen the jammed bushes and ur away, starter motor rebuild cost me about $350 hope that's helpful
Also from experience I would go an ultra heavy duty battery better safe then sorry
Edited by Chris_Beli
so... the auto lec had an opening today and was able to look at my car. may have been the name dropping i did of my uncle who used to work there, and he asked who's son i was, when i told him he was like oh yeah. turns out starter was completely f***ed not even worth trying to repair, so in went a brand new one, not genuine, or hitachi (which the old one was) but brand new, for the total price of...wait for it... $390.50. so i now have my car back for the weekend, which isn't bad considering he originally wouldn't get to it until atleast monday. :yes: very happy stagea owner up here in far north queensland
The most common thing that happens with RB starters is worn brushes.
Strip the starter, remove the brush plate; get an auto elec to replace the brushes (most people don't own a soldering iron with enough grunt to solder the new tails in), clean up the commutator; reassemble.
Good to go for another 20 years. ;)
I hate the Bosch starter that Holden used on the VL's; makes them sound like a red motor at startup. :yucky: The Hitachi has a much nicer (quieter) planetary drive.
Edited by Daleo
pretty sure the r31's use the nice sounding one
well my 31 sounds normal, i think my 32 may have had a vl one tho thinking back
Yep, the Hitachi one is the nice one; all Nissan's should be fitted with this one.
No idea why Holden went with the Bosch.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
