Max Amps Pulled From Battery / Cable Gauge Required To Relocate Battery To Boot
I searched for a DIY guide on relocating the battery to the boot, and surprisingly couldn't find anything!
Can anyone advise on the minimum cable gauge required to relocate the battery to the boot? I have a heap of 8AWG cable (61Amp capable) which I realise is probably not going to be sufficient, but I am just wondering if I run 2 of the lines if it will be enough?
Cheers :cheers:
Justin
depending on the quality of the cable i recommend 2awg as a minimum preferably larger,
i measure a starter on a v6 commodore 160amps on cranking. which has lower compression so i assume less work would be needed to crank.
Cheer's for the responses :no: Looks like even 2 x my 8AWG wire is not going to cut it!!!
I think I will leave the battery relocation for another time.
2ga is more than plenty, it is also the same as the -ve line from a mig welder. Hit up BOC gas and just buy some welding cables, works out cheaper than 2ga audio cable :)
My Gtr had the battery relocated to boot, used 2gauge cable, never have a problem with voltage drop or any other electrical problems (apparently these cars are voltage sensitive)
6 Cyl Starter motors usually draw between 200-400 amps. No amplifier wire is going to cut it. You need minimum 2 gauge battery/starter cable. It's about $10/m at repco from memory
welding cable works out a tad cheaper if you have a trade account :)
Also don't forget your starter motor will draw more current in winter and also when the battery is lower in voltage. You need to account for these factors so you don't catch things on fire. Safety first :)
I used 0 gauge audio cable. And I ran both earth and positive. I didn't want to earth though the body. U can't go wrong with over earthing.
Cost alil bit, but I hate wiring probs so I just over killed it so there won't b issues.
  • 4 weeks later...
What are people using for distribution blocks once they have relocated the battery? Having a bit of a look at options for such things at the moment.
stereo components really.. you just need a good ANL fuse & holder that that's it.. don't waste your time with anything else :)
Custom made...
Neutral bar with stand offs in a jiffy box.
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
