I wasn't really blown away by the RC of windows 8 but it was functional for the most part (i was concerned about not having MC with it but M$ have changed their minds possibly i couldnt confirm on the M$ website) Source
and it certainly was a bit snappier to load on a SSD, my thinking is for a $40 upgrade you cant really go wrong?
other peoples opinions?
seems there is only 2 versions also?
Windows 8 Pro
and
Windows 8 Pro Pack
that later having remote desktop stuff and something else that escapes me atm
https://www.sau.com.au/forums/topic/412615-windows-8-upgrade/
  • Replies 48
ok deeper research shows Media Center does indeed NOT come with Windows 8 and is purchased as an addon pack
BUT for the time being it will be free
http://windows.microsoft.com/en-US/windows-8/feature-packs
** Windows 8 Media Center Pack is available at no charge for a limited time only through this promotional page on Windows.com. If you obtain Windows 8 Media Center Pack through any other location fees might apply. Offer valid from October 26, 2012, until January 31, 2013, and is limited to one product key per email address. You qualify for this promotion if your PC is running Windows 8 Pro....
Where do you go to access "device manager" on windows 8?
I usually just right click on my computers from the start menu & go from there, but they removed the whole thing...
So far it looks like I'll give this a miss for my main computer & mayble upgarde this on my ultrabook so I can get used to it.
Well my upgrade was hindered by windows 8 choosing another driver for my lifeview tv tuner and because lifeview didn't support 64bit I always had to force windows to not upgrade drivers and choose the chipset drivers, which always worked fine
Oh well will get something sorted
Interesting to see there are already 'fixes' for some of the changes in the interface, such as the Start menu, but everyone at work who has migrated over is about 90% in favour. I'll be migrating my sister's laptop on the weekend, fresh install since technically I'm upgrading her Dell from Vista.
We've had a ton of charities getting donated copies too. Sounds like Win8 is a good way to get more life out of old computers.
update: just pulled the TV tuner out of my pc to get model numbers off the chipset, a quick google and i have found the BDA drivers and im a happy camper again
i have a 120gb Sata3 ssd Ryan and from power on to using windows is about 30secs including POST
Well coming from windows 7 and no SSD (it took me using a friends computer to realise what I was missing out on) going to windows 8 and a vertex 4 I can finally say this is definitely a step in the right direction for microsoft. It will take some people a while to get the hang of it. Just a few helpful shortcuts for those that are new.
Press together when you're on the desktop.
  • Windows Key + X = Brings up a text menu to access all the important (and usually relevant) features of windows
  • Windows Key + F = Brings up the search menu to find programs etc...
  • Windows Key + E = Brings up 'My Computer
  • Windows Key + C = Brings up Date/time + Side menu
Hope that helps some people get around a little easier ;)
Edited by Reflector
I've had a play with it. It's great for tablets/anything with a touch screen. But once you use it for typical office stuff and non touch devices - it's rather cumbersome... May grow on me. But at this point in time I'm not sold on it - unless I'm using a tablet.
over 98% of my use has been in desktop mode and nothing has changed for me in that view
my daughter on the other had has had a play with "Metro" and i think mum likes metro but haven't had the chance to speak to either of them in depth about it
with Start8 bar it boots me straight into desktop http://www.stardock.com/products/start8/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
