well... Since I'm having a baby and I barely drive the car anymore, I have finally decided it's time to move on.
Up for grabs is my 1994 R33 Gts-t. built with the highest quality Japanese parts and no expense spared, not only does this car make heaps of power, it makes it quickly, easliy, agressively and most importantly... reliably.
I have had this car for 7 years and am the second Australian owner. My best mate imported it in about 2003 and it has been looked after like a child ever since. The car came over stock and has been entirely modified by myself. The car was put together using only the best japanese parts, all chosen to compliment each other.
The car was tuned on 98 ron with the factory turbo and ran at 185rwkw for a few years, and later became one of the first cars on SAU to be tuned on e85, finally cracking the 300rwkw mark back in 2009.
After 3 years of 300+ rwkw the old motor finally popped (big end) and got replaced with a low km unit out of a stagea. This motor has been installed and tuned, and has only seen 1 motorkhana day.
As the motor is out of a stagea, it has an RB26 block with the larger alloy sump and RB25 internals.
It also spent it's whole life attached to an auto box and came out of a non performance modded showcar that was unable to be complied.
The car currently makes 290rwkw on BP Ultimate @ 19 psi and a huge 323rwkw on E85 - all tuning by Trent @ chequred tuning (Status)
car sees full boost by 3200rpm and makes power right up to the 7400rpm redline
Car has been on it's track tune of approx 275rwkw @ 17psi since the new motor was installed.
I never run it on more than this as there really isn't any need.
mods:
1998 Nissan Stagea RB25 - 75,000km (100k service done less than 5,000 ago) (chassis approx 150,000km)
HKS GT 2835 Pro S Turbo (.68)
Nismo 555cc Injectors
Nismo Intank fuel pump
Nismo Z32 AFM
Splitfire Coilpacks
New OEM radiator
Hybrid GT Front Mount intercooler (matte black)
Greddy 1lt catchcuan (both rockers to can, pcv blocked, rocker to plenum connected)
Steel intake pipe
Custom cold air box with cold air intake
Apexi pod filter
ARP Exhaust manifold studs
Veer metal gaskets (turbo, and manifold)
Rocker covers removed, painted and resealed with new oem gaskets
Greddy RB26 Exhaust cam gear
Apexi 3" front pipe
Custom 3" decat pipe welded into face cat
Custom 3" genie rear pipe, tucked up into body
Hotdog and Genie cannon (4" tip)
Gates racing timing belt
RB30 water pump
New OEM engine mounts
RB26 5.5lt alloy sump (front diff removed)
Exedy HHHDBC (triple heavy duty button clutch) with GTR pressure plate
Nismo GT LSD Pro 1.5 TT diff (serviced every 5000km with motul comp fluid
Greddy Type S coilovers with cabin adjust for rears (6/8 springrate)
Selby's swaybars front and rear
superpro camber bushes front and rear
superpro caster bushes front
superpro pineapple bushes
hicas lock bar (globe removed)
DBA 4000 296 ml slotted rotors
EBC redstuff pads
Motul dot 5.1 fluid
Varrstoen 2.2.1 18x9.5+12 all round w 235/40/18 Falken ZE912 - satin black (not included unless you want to buy them seperately as will put on new car)
Rays engineering red titanium wheel nuts
hub locator rings
GTR Front bar (fibreglass)
GTR Grill (fibreglass)
Ganador Mirrors (genuine - carbon)
JDM tyte yo roof spoiler
Carbon boot lip
New OEM nissan headlights (2011)
Phillips crystal vision globes
front indicators deleted and relocated to parkers
resprayed in oem wine red
darkest legal tint on rear window
graduated tints on side windows
Trico chameleon wipers - re- sprayed in satin black
Bride Ergo drivers seat - blue with grey graduated bride logo
bride superlow rails
R33 GTR passenger seat
CAMS authorised 1kg fire extinguisher
150mm clear bubble dildo shifter
C's Short shifter ( 30% shorter throw)
G-tech hanbreak drift button
Rocket switch (disconnected)
replaced OEM gearboot & handbrake leather
330ml Nardi wheel with perforated leather and red stitching
50mm alloy steering wheel spacer
HKB boss kit
666 dan 5 way white in dash LED's
hicas globe removed
Apexi Power FC computer
Blitz DSBC spec S boost controller
Apexi 1.8 bar boost guage on pillar mount
autometer phantom oil temp guage
autometer phantom water temp guage
autometer phantom air fuel guage (narrowband)
Apexi turbo timer
Pioneer AVH-P5750DVD single din DVD player with 6.5" fold out screen (works while driving)
Nintendo Gamecube
Polk Audio db 6.5" splits
JL Audio 6x9's
Optima Yellowtop battery with stinger terminals
If i remember any more mods i will update this list
After $16,000 - no RWC - plates not included. $15,000 with out rims. please don't lowball me with 50% offers, as I will not reply. this car has had a LOT of $$$ spent and is worth every penny i'm asking.
contact: 0433 362 156
http://s295.photobucket.com/albums/mm144/hamishhampton/?action=view&current=MOV00074.mp4
311 rwkw (e85 @ 18 psi) run from 2009 (i think) on the old engine (new one is far more agressive)
still up for grabs man... I just realised what you meant by that comment... post has been edited to remove confusion. thanks for that :)
Jesus H Christ Hamish, your literally giving this thing away....what the hell man!?. Congrats on your baby btw. Are you keeping the Pimp Stick?
my favourite Gtst...after Al's :P
They are tied for me, although Al's is generally "cleaner" I've never seen it really go. Al's car is the car I want with the hood up in my glass garage adjacent to my living room on a lazy susan. Hamish's car is the car I want when I'm out and about and trying to impress de ladiezzzz ;).....and as you can CLEARLY see it worked for Hamish
Whoever buys this woody-inducing car will become nearly as rad as Hamish himself
Edited by JamesK
Warning to prospective buyers:
thanks for the kind words guys!
I do realise that the price is quite cheap for what has gone into this car, hence the price being pretty firm.
I do not need it to be gone in 24hrs or anything drastic, hence only having it advertised on SAU, as I really want a member to buy this car.
forgot to mention there is a small scrape on the front bar where i hit my driveway, and the inside door trim where the window switches are has a small crack on it.
in an effort to get this car to stay in the club i'm happy to knock $1k off the price mentioned above if a forum or club member buys it.
last chance for SAU members only deal.
willing to take 13k without rims/plates/rwc if it goes within 2 weeks - beyond that it's going onto carsales and other forums and i'll hold firm until i get my price
stupidly cheap deal.
If you want what is probably the best road going gtst on the market at present, this is it... and it's going cheap!
car is now on hold for an interstate buyer.... will update here in a week if it doesn't go!
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
